[GRASS-dev] r.to.rast3 error messages
Hi devs,
When running r.to.rast3 with as input two integer maps:
r.to.rast3 input=soc_0_5cm_mean,soc_5_15cm_mean output=test
I am getting the following two warnings:
WARNING: G__open_misc(read): Unable to open ‘/home/paulo/grassdb/Schijndel/soils/cell_misc/soc_5_15cm_mean/nullcmpr’: Too many open files
WARNING: G__open(read): Unable to open ‘/home/paulo/grassdb/Schijndel/soils/cellhd/soc_5_15cm_mean’: Too many open files
and the error message:
ERROR: Error reading reclass file for raster map soc_5_15cm_mean@soils
I am really not sure what these messages are about. The warning messages do not seem to make sense, I am only using two files as input. I do not understand the error message either, or what the reclass is referring to.
Any idea, is this a bug I should report, or something I am doing wrong?
Mvg.
Paulo
On Sun, Jul 18, 2021 at 5:57 AM Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Hi devs,
Any chance you are running something else at the same time? Generally, there is a limit on the number of open files (see e.g. r.series man page).
Mvg.
Paulo
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Mon, Jul 19, 2021 at 4:14 AM Anna Petrášová <kratochanna@gmail.com> wrote:
Hi devs,
I thought of that, but the same error occurred after running the function as first thing after restarting grass gis.
Mvg.
Paulo
On Mon, Jul 19, 2021 at 5:16 AM Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Hi devs,
It could be influenced by other processes apart from GRASS, the limit is not per program but per user (I think). Sorry, no better idea here.
Mvg.
Paulo
