[GRASS-dev] r.topmodel: doubled 'ovewrite switch'
Hi!
r.topmodel has it's own 'overwrite output' switch. Since the Grass-wide
'--ovewrite' has been documented, r.topmodel manual reads:
-o
    Overwrite outputs
--overwrite
    Force overwrite of output files
Does the r.topmodel's '-o' imply exactly the same as the Grass-wide
'--ovewrite'? Could the r.topmodel's own switch be removed now?
Maciek
Fixed in CVS.
Huidae Cho
On Tue, Jul 18, 2006 at 08:16:52PM +0200, Maciej Sieczka wrote:
Hi!
-o
    Overwrite outputs
--overwrite
Maciek
