it seems pretty harmless, I don't see why not. But then again I thought
the same thing about r37726 when I committed it, and then trac #654
turned up. So lately I've been much more wary about backporting things
due to the wrath of unintended consequences. I figure we can always
let a few new trival features dribble in to 6.4.1 before being fully
strict about only allowing bug-fixes into the 6.4 branch- as long as
they are merged soon after the 6.4.0 release for maximum testing before
6.4.1.
> does that %d (and n= and null_cells= above it) want to be %ld or
> something to be LFS-safe?
> fprintf(stdout, "cells=%d\n", stats->size);
> e.g. IIUC signed int overflows at a sqrt(2^31) = 46341 x 46341
> rows x cols raster region size. Which people are getting closer to
> these days...
Markus wrote:
Right - I guess that the entire output of r.univar needs to be revised
for that.
not just the output, the innards as well. I see in global.h that both
n and size are plain signed int. Not sure why n was changed away from
being unsigned int, it used to be like that in the original C version.
(unsigned int would survive up to 65536x65536 cells, IIUC)
Also, I've been wondering whether to apply the %.7g for FCELL, %.15g
for DCELL output formats for r.univar min/max/stdev output as part of
trac #335.
