[GRASS-dev] r.viewshed -memory problem
Hi Folks,
I am try to use GRASS7 SVN on win 7. I tested new modul r.viewshed on
large dataset. But some problem with memory.
not shure if it is my mistake or bug.
Jan Trochta
r.viewshed -e --overwrite --verbose input=STRomy@boubin output=pk
coordinate=-803821.575747913,-1158866.72289775 max_dist=1500
Memory manager registering memory in MM_WARN_ON_MEMORY_EXCEEDED mode.
Nodata value set to -1.#QNAN0
rows=14293, cols=12816, total = 183179088
In-memory memory usage is 18318011328 B (17469 MB), max mem
allowed=524288000 B(500MB)
***** EXTERNAL_MEMORY MODE *****
Intermediate files will not be deleted in case of
abnormal termination.
To save space delete these files manually!
Estimated size active structure:
(key=64, ptr=4, total node=80 B)
Total= 1143440 B
Start sweeping.
Computing events ...
Sorting events...
MM warning: limit=524288000B. allocating 261881248B. limit
exceeded by 2520B.
exceeded by 2598B.
exceeded by 2676B.
exceeded by 2754B.
exceeded by 2832B.
exceeded by 2910B.
exceeded by 2988B.
exceeded by 3066B.
exceeded by 3144B.
exceeded by 3222B.
exceeded by 3300B.
exceeded by 3378B.
exceeded by 3456B.
exceeded by 3534B.
exceeded by 3612B.
exceeded by 3690B.
exceeded by 3768B.
exceeded by 3846B.
exceeded by 3924B.
exceeded by 4002B.
exceeded by 4080B.
exceeded by 4158B.
exceeded by 4236B.
exceeded by 4314B.
exceeded by 4392B.
ami_single_temp_name: mktemp failed: : File exists
Assertion failed: 0, file ami_stream.cpp, line 97
This application has requested the Runtime to terminate it
in an unusual way.
Please contact the application's support team for more
information.
(Tue Jan 10 12:57:51 2012) Command finished (17 min 22 sec)
On Tue, Jan 10, 2012 at 1:03 PM, Jan Trochta <j.trochta@gmail.com> wrote:
Hi Folks,
Jan Trochta
please also post the output of
g.region -p
Hi Folks,
Jan Trochta
The memory-related warnings can be ignored. The limit of 500MB is
exceeded by 4MB or 0.8%, nothing tragic. The error
is tragic, however.
The problem could be related to wrong directory separators used by
ami_single_temp_name (/ instead of \), needs testing. But it's
definitively not your mistake.
Markus M
Total= 1143440 B
Start sweeping.
Sorting events...
exceeded by 2520B.
exceeded by 2598B.
exceeded by 2676B.
exceeded by 2754B.
exceeded by 2832B.
exceeded by 2910B.
exceeded by 2988B.
exceeded by 3066B.
exceeded by 3144B.
exceeded by 3222B.
exceeded by 3300B.
exceeded by 3378B.
exceeded by 3456B.
exceeded by 3534B.
exceeded by 3612B.
exceeded by 3690B.
exceeded by 3768B.
exceeded by 3846B.
exceeded by 3924B.
exceeded by 4002B.
exceeded by 4080B.
exceeded by 4158B.
exceeded by 4236B.
exceeded by 4314B.
exceeded by 4392B.
in an unusual way.
information.
grass-dev mailing list
grass-dev@lists.osgeo.org
I tried decrease resolution to 0.2 and its work.
g.region -p:
projection: 99 (Krovak)
zone: 0
datum: towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56
ellipsoid: bessel
north: -1158293.493
south: -1159681.061
west: -804210.292
east: -803341.459
nsres: 0.09999769
ewres: 0.1000038
rows: 13876
cols: 8688
cells: 120554688
Jan
Dne 10. ledna 2012 14:09 Markus Metz
<markus.metz.giswork@googlemail.com> napsal(a):
Hi Folks,
Jan Trochta
is tragic, however.
Markus M
Total= 1143440 B
Start sweeping.
Sorting events...
exceeded by 2520B.
exceeded by 2598B.
exceeded by 2676B.
exceeded by 2754B.
exceeded by 2832B.
exceeded by 2910B.
exceeded by 2988B.
exceeded by 3066B.
exceeded by 3144B.
exceeded by 3222B.
exceeded by 3300B.
exceeded by 3378B.
exceeded by 3456B.
exceeded by 3534B.
exceeded by 3612B.
exceeded by 3690B.
exceeded by 3768B.
exceeded by 3846B.
exceeded by 3924B.
exceeded by 4002B.
exceeded by 4080B.
exceeded by 4158B.
exceeded by 4236B.
exceeded by 4314B.
exceeded by 4392B.
in an unusual way.
information.
g.region -p:
zone: 0
ellipsoid: bessel
north: -1158293.493
south: -1159681.061
west: -804210.292
east: -803341.459
nsres: 0.09999769
ewres: 0.1000038
rows: 13876
cols: 8688
cells: 120554688
Ja,
do you really have a 10cm (!) resolution DEM there?
Perhaps you want to adjust the resolution to that of the DEM.
Best
Yes, Its 10 cm, but it is not DEM.I wish to simulate lidar scanning in
forest. I would like to know how far can terrestrial lidar find trees.
Thats why I have so detailed resolution.
Jan
Dne 10. ledna 2012 22:06 Markus Neteler <neteler@osgeo.org> napsal(a):
g.region -p:
zone: 0
ellipsoid: bessel
north: -1158293.493
south: -1159681.061
west: -804210.292
east: -803341.459
nsres: 0.09999769
ewres: 0.1000038
rows: 13876
cols: 8688
cells: 120554688
Ja,
Best
