[GRASS-dev] r.volume - error: reading raster at row x outside of region
Hi devs,
I have 2 rasters:
r.info map=sample_tallard_eu_dem_westernalps_slope
| Map: sample_tallard_eu_dem_western Date: Sun Apr 24 20:36:43 2016
| Mapset: westernalpsriver Login of Creator: bugs
| DataBase: /home/bugs/grassdata
| Title: slope in degrees ( sample_tallard_eu_dem_westernalps_slope )
| Timestamp: none
| Type of Map: raster Number of Categories: 77
| Data Type: FCELL
| Rows: 4713
| Columns: 4808
| Total Cells: 22660104
| Projection: Lambert Azimuthal Equal Area
| N: 2460525 S: 2342700 Res: 25
| E: 4098800 W: 3978600 Res: 25
| Range of data: min = 0 max = 76.56607
| Data Source:
| raster elevation file r_elevation_crop
| Data Description:
| generated by r.slope.aspect
| Comments:
| slope map elev = r_elevation_crop
| zfactor = 1.00 format = degrees
| min_slope = 0.000000
| r.slope.aspect elevation="r_elevation_crop" slope="sample_tallard_eu\
| _dem_westernalps_slope" aspect="sample_tallard_eu_dem_westernalps_as\
| pect" format="degrees" precision="FCELL" zscale=1.0 min_slope=0.0
r.info map=sample_tallard_eu_dem_westernalps_basin
| Map: sample_tallard_eu_dem_western Date: Sun Apr 24 20:36:03 2016
| Title: ( sample_tallard_eu_dem_westernalps_basin )
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: CELL
| Rows: 4713
| Columns: 4808
| Range of data: min = 1 max = 1
| Data Description:
| generated by r.stream.basins
| Comments:
| r.stream.basins direction="sample_tallard_eu_dem_westernalps_drainag\
| e_e" points="sample_tallard_eu_dem_westernalps_outlet_snap" memory=3\
| 00 basins="sample_tallard_eu_dem_westernalps_basin"
when I do r.volume with these rasters, I get:
r.volume --verbose input=sample_tallard_eu_dem_westernalps_slope
clump=sample_tallard_eu_dem_westernalps_basin
ERROR: Die Leseanfrage der Rasterkarte
<sample_tallard_eu_dem_westernalps_basin@> für Zeile -82 ist außerhalb der
Region.
ERROR: Reading of raster map <sample_tallard_eu_dem_westernalps_basin@> for
row -82 is outside the region.
D3/3: row=4712 col=4805: zero or negs ignored
D3/3: row=4712 col=4806: zero or negs ignored
D3/3: row=4712 col=4807: zero or negs ignored
100%
FEHLER: Die Leseanfrage der Rasterkarte
        außerhalb der Region.
the computational region:
g.region -p -a raster=eu_dem_westernalps@westernalpsriver
vector=v_region_durance_buffer5000@westernalpsriver
align=eu_dem_westernalps@westernalpsriver
projection: 99 (Lambert Azimuthal Equal Area)
zone: 0
datum: etrs89
ellipsoid: grs80
north: 2460525
south: 2342700
west: 3978600
east: 4098800
nsres: 25
ewres: 25
rows: 4713
cols: 4808
cells: 22660104
any idea what causes such an error?
r.volume, tested with a lot of other rasters of different extents, worked so
far ...
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-volume-error-reading-raster-at-row-x-outside-of-region-tp5262679.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
Helmut Kudrnovsky wrote
Hi devs,
I have 2 rasters:
| Timestamp: none
| Data Type: FCELL
| Rows: 4713
| Columns: 4808
| Data Source:
| Data Description:
| Comments:
slope="sample_tallard_eu\ |
aspect="sample_tallard_eu_dem_westernalps_as\ |
| Timestamp: none
| Data Type: CELL
| Rows: 4713
| Columns: 4808
| Data Description:
| Comments:
| r.stream.basins
direction="sample_tallard_eu_dem_westernalps_drainag\ |
memory=3\ |
&lt;sample_tallard_eu_dem_westernalps_basin@&gt; für Zeile -82 ist
&lt;sample_tallard_eu_dem_westernalps_basin@&gt; for row -82 is outside
the region.
100%
zone: 0
datum: etrs89
ellipsoid: grs80
north: 2460525
south: 2342700
west: 3978600
east: 4098800
nsres: 25
ewres: 25
rows: 4713
cols: 4808
cells: 22660104
so far ...
Maybe some memory issue?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-volume-error-reading-raster-at-row-x-outside-of-region-tp5262679p5262683.html
Hi Helli,
please consider to switch your session to a English language locale, eg
export LANG=en_US
export LANGUAGE=en_US
export LC_MESSAGES=en_US
Then more people may be able to follow the error messages you have sent.
Apart from that:
r.volume's "row -82" looks like an integer overflow to me. Just guessing...
cheers
Markus Neteler wrote
Hi Helli,
export LANG=en_US
Apart from that:
guessing...
cheers
sure, here it is:
ERROR: Reading raster map <sample_tallard_eu_dem_westernalps_basin@> request
for row -82 is outside region
yes maybe an integer overflow.
adapted the subject of the thread.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-volume-error-reading-raster-at-row-x-outside-of-region-tp5262679p5262705.html
