I realized that the r.drain function does not adequately create a
least-cost path on a cumulative cost surface. This is because there is
no check within the r.drain function to ensure that the "steepest"
downhill change in cost value is actually the same as the direction of
cost accumulation during the cost calculation. This means that there
is a disconnect between the movement direction in r.walk and the path
created by r.drain.
To fix this I have added the creation of a movement direction output
raster to the r.walk code. This way the original movement directions
will be preserved and the true least-cost path may be found using
another module which traces the directional surface backwards.
My question is, should the direction tracing module be:
a) incorporated into r.drain with a flag specifying a cost surface
rather than dem input, and an additional direction input
b) write a new, separate module called r.costpath
More modules or more complex modules?
Thanks for the advice,
-Colin
On Mon, Jun 23, 2008 at 4:02 AM, Colin Nielsen <colin.nielsen@gmail.com> wrote:
created by r.drain.
-Colin
Interesting post Colin. Can you comment on the differences between
r.drain and r.walk in this example [1], in light of your findings?
1. http://casoilresource.lawr.ucdavis.edu/drupal/node/544
Dylan
