[GRASS-dev] r.walk issues for 6.4.2?
One of my students was having problems with r.walk not properly reflecting surface topography in 6.4.2 svn (from a few weeks ago).
So I checked it out today. My comparison is not quite the same as hers as she is on Mac OS X 10.6.8 and I’ve tested this on 10.7.2 (Lion). But we’re using the same GRASS builds (done with 10.6.8 on my other computer).
I did not have the same problem she did. I tested with the Spearfish demo set. She is using a DEM in a Lambert Conformal Conic projection (which I suppose might be a problem for some reason).
However, I did turn up something of interest for the upcoming GRASS 6.4.2 release.
In 6.4.1, we did not include the new backlink map option, but I thought it was going to be in 6.4.2. So far it has not been backported from 6.5.
Also, running r.walk without the backlink in GRASS 6.4.2 and GRASS 7 produces significantly different results. Here are the links to a couple of outputs of a difference map between r.walk on 6.4.2 minus r.walk on GRASS 7 using exactly the same command and files.
r.walk elevation=“elevation.dem@PERMANENT” friction=“flat1m@PERMANENT” output=“cost1” start_points=“Elkhorn_Peak_site@G7_vector” max_cost=0 percent_memory=100 walk_coeff=“0.72,6.0,1.9998,-1.9998” lambda=1.0 slope_factor=-0.2125
http://dl.dropbox.com/u/7437464/rwalk_diff.jpg
http://dl.dropbox.com/u/7437464/rwalk_diff_histogram.png
As you can see, there are very patterned differences in the behavior of r.walk between the 2 GRASS versions. The differences are not huge (in the range of +3 to -13 minutes), but are still notable. Beyond adding the backlink option, do the r.walk algorithms differ significantly between them?
Also, has anybody had any problems with r.walk in a Lambert projection?
Michael
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
+1 for backporting the r.walk 6.5 patches
to 6.4.2. They make the module a lot more useful.
Ben
as she is on Mac OS X 10.6.8 and I've tested this on 10.7.2 (Lion). But
we're using the same GRASS builds (done with 10.6.8 on my other computer).
6.4.2 release.
r.walk elevation="elevation.dem@PERMANENT" friction="flat1m@PERMANENT"
output="cost1" start_points="Elkhorn_Peak_site@G7_vector" max_cost=0
percent_memory=100 walk_coeff="0.72,6.0,1.9998,-1.9998" lambda=1.0
between them?
Michael
____________________
C. Michael Barton
grass-dev mailing list
grass-dev@lists.osgeo.org
Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
   benducke@fastmail.fm
I am not sure whether it is relevant, but for our r.walk example here (nc_spm_08 data set)
http://courses.ncsu.edu/mea582/common/GIS_anal_grass/GIS_Anal_granal2.html
the results from GRASS6.4.1 and GRASS7 are identical (I haven't tried it for 6.4.2, I assume it is same as 6.4.1?)
Helena
So I checked it out today. My comparison is not quite the same as hers as she is on Mac OS X 10.6.8 and I've tested this on 10.7.2 (Lion). But we're using the same GRASS builds (done with 10.6.8 on my other computer).
r.walk elevation="elevation.dem@PERMANENT" friction="flat1m@PERMANENT" output="cost1" start_points="Elkhorn_Peak_site@G7_vector" max_cost=0 percent_memory=100 walk_coeff="0.72,6.0,1.9998,-1.9998" lambda=1.0 slope_factor=-0.2125
Michael
C. Michael Barton
Helena,
Have you tried it in a Lambert projection?
Michael
C. Michael Barton
Helena
Michael
C. Michael Barton
grass-dev Info Page
On Sat, Oct 8, 2011 at 5:29 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
release.
There should be no differences between GRASS 7 and GRASS 6.4, at least
in my tests there are no differences.
The problem you experience has most likely nothing to do with Lambert
projection, instead I suspect with the resolution of 1km posted in the
ticket. Even though the results appear to make sense in geographic,
this is pure accident. In fact, r.walk is not supposed to work with
geographic because r.walk assumes meters as both horizontal and
vertical units.
The formula given in the manual and implemented in (all versions of)
r.walk is IMHO weird because the c coefficient results in negative
time required to cross a moderate downhill slope, but walking humans
can not travel backwards in time, and the Dijkstra search requires for
good reason positive costs. With large horizontal resolutions, e.g.
1km, the time required to cover the distance from one cell to the next
cell is much larger than most encountered slopes. At least the r.walk
algorithm behaves likes this, which results in a sort of manhattan
distance map as obtained in a flat landscape.
Markus M
I got these differing results with elevation.dem in Spearfish, a UTM projection. The Lambert issue is a different one.
I'm not sure why r.walk should not work in a Lambert projection since the horizontal and vertical units are all in meters.
Michael
______________________________
C. Michael Barton
Tempe, AZ 85287-2402
USA
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
release.
vertical units.
Markus M
All I can say is that I did the following: I ran the exact same r.walk command in GRASS 7 and GRASS 6.4.2 on the same map in the Spearfish demo, on the elevation.dem topographic map. I then did a difference map of the results of these two r.walk runs.
Michael
C. Michael Barton
USA
Helena
Michael
C. Michael Barton
grass-dev Info Page
Hi Markus,
I didn't read this close enough. Thanks for the explanation.
Michael
C. Michael Barton
USA
So I guess it is not a resolution issue.
Michael
C. Michael Barton
On Oct 10, 2011, at 2:52 PM, Claudine Gravel Miguel wrote:
Hello,
so I reran it making sure I had the region at a high resolution (90m), and the result is the same. I’m attaching the output txt of the whole computation (with the info on the region) and the image showing the resulting raster. On a related note, this ‘flat’ walk was also produced when I tried running r.walk in a re-projection of a geoTIFF in UTM. This both in GRASS 6.4 and 7.
Thanks
Claudine
On Mon, Oct 10, 2011 at 2:32 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
Hi Markus,
I didn’t read this close enough. Thanks for the explanation.
Michael
C. Michael Barton
USA
<grass_cmd_history_walk.txt><Results_walk_Conical.png>
