Hi
Just had a long chat with myself on grass-user in which I eventually figured
out that r.water.outlet would need an extra line added to work with lat/lon
grids that involved the 180 meridian wraparound. The modification to main.c
is (with surrounding lines for context) is:
G_usage();
exit(EXIT_FAILURE);
E = G_adjust_east_longitude(E,window.west); // <-- NEW LINE; for using
lat/lon data that straddle the 180 meridian
if (E < window.west || E > window.east || N < window.south ||
N > window.north) {
Along with this, should the HTML help be updated to not just say
"northing/easting" for pour point locations, but also say "lat/lon"?
it would be fine if you could open a ticket in trac for this issue
(http://trac.osgeo.org/grass/wiki#BugTracking ,
http://trac.osgeo.org/grass/report) and, if possible, add a patch
there (http://trac.osgeo.org/grass/wiki/HowToSVN#LocalDiffs), so all your
work isn't getting lost in the mailing list.
best regards
Helmut
___________________________________________________________
Schon gehört? WEB.DE hat einen genialen Phishing-Filter in die
Toolbar eingebaut! http://produkte.web.de/go/toolbar
On Sat, Jul 2, 2011 at 3:19 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
Hi
G_usage();
exit(EXIT_FAILURE);
E = G_adjust_east_longitude(E,window.west); // ← NEW LINE; for using
N > window.north) {
“northing/easting” for pour point locations, but also say “lat/lon”?
work isn’t getting lost in the mailing list.
best regards
Helmut
Thanks for letting me know! I will do that.
Andy
