[GRASS-dev] r.watershed not compiling
OK. Now that William has helped catch a stupid error on my part, I can report a real problem with compilation on the Mac.
The new improved r.watershed is not compiling. Here is the error.
Finished compilation: Wed Feb 25 20:40:50 MST 2009
make: *** [default] Error 1
cmb-MBP-2:grass6_src cmbarton$ cd /Users/cmbarton/grass_dev/grass6_src/raster/r.watershed/front
cmb-MBP-2:front cmbarton$ make
gcc -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.6.0/include -arch i386 -Os -DPACKAGE=\""grassmods"\" -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.6.0/include -o OBJ.i386-apple-darwin9.6.0/main.o -c main.c
main.c: In function ‘main’:
main.c:244: error: syntax error before ‘<<’ token
make: *** [OBJ.i386-apple-darwin9.6.0/main.o] Error 1
I am very much looking forward to trying this in GRASS 6.5 and appreciate the effort to backport the multiflow direction improvements. I hope that this issue can be corrected.
Michael
check for
in the source code from a svn merge conflict.
Hamish
That was it. Thanks.
Michael
check for
Hamish
