[GRASS-dev] r.watershed problem
I am trying to get streams out of srtm map of Mekong Basin.
my laptop is 2 Gb RAM and enough HDD space. I tried with and without
-m flag, same result. Any idea/suggestion?
thanks
Yann
GRASS 6.3.svn (Sub1):~/tmp/grass/gui/wxpython/gui_modules >
r.watershed --overwrite elevation=mekong_srtm@test
stream=mekong_streams threshold=50000 -m
SECTION 1 beginning: Initiating Variables. 5 sections total.
WARNING: No such file or directory
WARNING: cseg_open(): could not write segment file
WARNING: category information for [mekong_streams] in [test] missing or invalid
GRASS 6.3.svn (Sub1):~/tmp/grass/gui/wxpython/gui_modules > r.info mekong_srtm
| Layer: mekong_srtm Date: Sat Mar 15 17:22:25 2008 |
| Mapset: test Login of Creator: yann |
| DataBase: /home/yann/GRASSDATA |
| Title: ( mekong_srtm ) |
| Timestamp: none |
| Type of Map: raster Number of Categories: 3058 |
| Data Type: CELL |
| Rows: 16923 |
| Columns: 9558 |
| Total Cells: 161750034 |
| Projection: Latitude-Longitude |
| N: 24:02:14.65386N S: 9:56:05.856936N Res: 0:00:02.999988 |
| E: 108:39:25.435332E W: 100:41:31.550028E Res: 0:00:02.999 |
| Range of data: min = -28 max = 3058 |
| Data Description: |
| generated by r.mapcalc |
| Comments: |
| if(mekong == 1, srtm_sea, null()) |
