Should r.watershed be giving negative accumulation values? I ran it on the spearfish 30m DEM and got results that are increasingly positive downstream for one drainage (as I would expect) and increasingly negative downstream for other drainages (I would not expect this). Do I misunderstand what accumulation is supposed to do?
Here is r.info for the results.
r.info atest_rwaccum
| Layer: atest_rwaccum Date: Sat Dec 20 00:08:40 2008 |
| Mapset: PERMANENT Login of Creator: cmbarton |
| DataBase: /Users/Shared/grassdata |
| Title: Watershed accumulation: overland flow that traverses each cell ( |
| Timestamp: none |
| Type of Map: raster Number of Categories: 81709 |
| Data Type: CELL |
| Rows: 466 |
| Columns: 633 |
| Total Cells: 294978 |
| Projection: UTM (zone 13) |
| N: 4928000 S: 4914020 Res: 30 |
| E: 609000 W: 590010 Res: 30 |
| Range of data: min = -90540 max = 81709 |
| Data Source: |
| elevation.dem@PERMANENT |
| Data Description: |
| generated by r.watershed |
| Comments: |
| Processing mode: All in RAM |
| r.watershed elevation="elevation.dem@PERMANENT" accumulation="atest_\ |
| rwaccum" memory=300 |
(Sat Dec 20 00:09:19 2008) Command finished (0 sec)
I am running this on my Mac using GRASS 6.4SVN from 10 December. If there was a major bug fix since that date, I can recompile tomorrow.
Michael
