[GRASS-dev] r.watershed updates
Now the lots-of-colors bug is fixed, I've now run r.watershed on a large
grid (5000x5000 cells [20% null]). It took 54 hours, basin/half-basin
results look nice, especially with: "nviz elev=topo color=basins.half"
r.terraflow with the same area & mem=1500MB took just minutes, but only
outputs sink-watershed basins, not all basins. (I may be missing
something here, this is all outside my field)
some weirdness/comments:
Accumulation map: number of cells that drain through each cell
| Range of data: min = -16269552 max = 8562412
(way negative? way postive?) bulk of data is 0->2000 though, so after
setting color rules the map looks ok.
stream map: 0 -> null
basins,half-basins: 0 -> null
length-slope, slope-steepness maps show a lot of cross-hatching
artifacts. (dem is r.contour output; slope, pcurv, tcurv look alright)
with such a long processing time the iterative process of picking the
correct threshold size requires a bit of planning.
used ~ 570mb RAM (all-in-memory mode)
Hamish
On Oct 29, 2006, at 4:22 AM, Hamish wrote:
Hi Chuck - it is great to see you involved again. Thanks for looking at
the color problem - it was a long standing issue that you were the best person
to resolve. We use r.watershed a lot with lidar and SRTM data and it works
very well.
r.terraflow is not designed to output basins the way r.watershed does.
there is another code that I hope will be eventually contributed that takes
terraflow output and creates a map of watershed hierarchy.
Did you read the manual?
I am not sure what you mean here, but I think that is because of the D8
algorithm. For LS factor that should be computed only for hillslopes
(becuase that is what USLE/RUSLE is for)
r.flow works better with Dinf method.
  But for stream networks it is hard to beat r.watershed.
(Chuck you should write a full paper about it - I get
lot of questions about the algorithm and where it is published that I cannot answer,
the proceedings paper does not give too much detail.
If you would like some good applications, I have plenty.)
Helena
Hamish
grass-dev mailing list
grass-dev@grass.itc.it
> after setting color rules the map looks ok.
not well enough apparently :slight_smile: now I have & understand what it means
Hamish
