[GRASS-dev] r38602 breaks scripts
r38602 modified all of the scripts to use _(...) to localise messages:
http://trac.osgeo.org/grass/changeset/38602
The main problem problem with this is that the _() function isn't
defined, so any script printing a message fails.
Presumably lib/python/core.py is supposed to initialise gettext, e.g.:
http://docs.python.org/library/gettext.html#localizing-your-application
2009/8/3 Glynn Clements <glynn@gclements.plus.com>:
hopefully fixed r38608.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
