[GRASS-dev] r67535: pygrass: change dirname in set_path()
Hi Martin,
I saw your recent comment in the set_path function:
TODO: why dirname is checked first - the logic should be revised
TODO probably also ‘path’ should be also removed - it’s used only by
compilation process for addons (see r.green for details)
‘path’ it is not used for compilation process for addons as you said. ‘path’ is used to run the code locally without compilation.
In this way it is possible to just unpack the module and call the sub-modules locally, compilation is not needed at all… This it is particularly useful during the development phase but not only. It works quite well also to overcome eventually g.extension problems.
Of course dirname must be checked before the default path, other wise it is too late…
Any comments?
Have a nice day
Pietro
2016-01-11 12:16 GMT+01:00 Pietro <peter.zamb@gmail.com>:
too late...
hm, what means `dirname`? I got impression that it's used for
$GRASS_ADDON_BASE/etc/r.mymodule
is find by set_path('r.mymodule')
$GRASS_ADDON_BASE/etc/r.mymodule/lib1
is find by set_path('r.mymodule', 'lib1'). From this logic I don't
understand why dirname must be set. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Hi Martin,
Sorry for the delay.
On Tue, Jan 12, 2016 at 7:11 PM, Martin Landa <landa.martin@gmail.com> wrote:
dirname must be set to check if the directory is available when using
the code locally, if dirname is available in the local specified path
then add the path to sys.path, otherwise try to find the correct path
within the GRASS standard paths.
I've added some more documentation to clarify this point.
Let me know if you think is still not clear. :slight_smile:
all the best
Pietro
Hi Pietro,
2016-01-25 11:31 GMT+01:00 Pietro <peter.zamb@gmail.com>:
Thanks, Martin
Martin Landa
In r67669 I moved the functions to grass.script.utils to avoid ctypes dependency. Backwards compatibility is kept. Documentation says depreciated. Old functions can be removed in 8.0.
https://trac.osgeo.org/grass/changeset/67669
On Mon, Jan 25, 2016 at 5:31 AM, Pietro <peter.zamb@gmail.com> wrote:
Hi Martin,
hm, what means dirname? I got impression that it’s used for
is find by set_path(‘r.mymodule’)
is find by set_path(‘r.mymodule’, ‘lib1’). From this logic I don’t
I’ve added some more documentation to clarify this point.
all the best
Pietro
grass-dev mailing list
grass-dev@lists.osgeo.org
2016-01-25 21:05 GMT+01:00 Vaclav Petras <wenzeslaus@gmail.com>:
thanks, make sense to me. Ma
Martin Landa
I’m still unsure whether we cover all cases correctly. Shouldn’t the compilation path options precede the normal ones?
For the record, added to
https://trac.osgeo.org/grass/wiki/Grass8Planning
