[GRASS-dev] random colors in d.vect
I have tried to implement *random* colouring based on category number
(according to layer number can be implemented later before CVS
committing...), see the attached patch.
I do not completely understand why you need to use in level 2
Vect_line_alive() + Vect_read_line() in contrast with level 1 and
function Vect_read_next_line (). In any case the functions
Vect_read_line () and Vect_read_next_line behave in the same way -
they may return 'line number', -1 or -2. So I do not know why
variable 'ltype' is tested only (switch (ltype)) in level 1.
Best regards, Martin
PS: Temporarily I have no GNU/Linux PC with Internet connection, so
this patch is against CVS snapshot from 2006/05/27.
(attachments)
d_vect_random_cols-2006-05-31.diff.gz (1.82 KB)
What's different between 'd.vect -c' and your patch? The -c flag also
implements random colors based on category/layer number.
Huidae Cho
On Wed, May 31, 2006 at 11:36:10AM +0200, Martin Landa wrote:
grass-dev mailing list
grass-dev@grass.itc.it
the difference is that the current implementation use 'pseudo random'
colors (e.g. cat % palette_ncolors), i.e. the color composition is
always the same. The patch changes this behaviour, it means, you will
not get the same colours by d.vect -c (it is useful if you do not like
the current colors).
Best, Martin
2006/5/31, Huidae Cho <grass4u@gmail.com>:
Huidae Cho
> Hi all,
I have rewritten the previous patch. I have separated the added code
to a function random_color() and tried to clean the code. Now it works
also for layer=-1 (i.e. according to layer number). There is also a
small bug in the current d.vect. Flag -c does not work (in connection
with layer=-1) for areas. It should be also solved. Please test it if
you like, I have no access to the CVS...
Best, Martin
PS: I think that default value for parameter 'layer' should be -1
instead of 1. Generally, I want to display all objects no matter which
layer they are stored in.
2006/5/31, Martin Landa <landa.martin@gmail.com>:
Best, Martin
> Hi,
> Huidae Cho
> > Hi all,
> > _______________________________________________
(attachments)
d_vect_random_cols-2006-06-01.diff.gz (2.29 KB)
Martin Landa wrote:
Any chance of allowing random colors according to an attribute column instead of cat ?
Moritz
good idea, I will try to add it...
Best, Martin
2006/6/2, Moritz Lennert <mlennert@club.worldonline.be>:
Martin Landa wrote:
> Hi all,
instead of cat ?
Moritz
