[GRASS-dev] Raspberry PI using Raspbian (debian) can compile and run grass trunk
just an info about compiling GRASS trunk (v7) in a Raspberry PI (256Mb
RAM version)
Screenshot:
http://grass.osgeo.org/uploads/images/Gallery/platforms/grass7_RaspberryPI.png
How-to:
Use Raspbian (http://www.raspbian.org/) as your SD card image
Start the Raspberry PI with that SD card
You will be presented with a (non-graphical) start menu:
- Extend the File system to the fill the SD card
- Overclock to 900MHz (needs 1V power more) or more (1GHz possible)
- Set up ssh server if you want to connect remotely
- go ahead to load the Debian LXDE interface
Open a terminal
sudo apt-get update
sudo apt-get dist-upgrade -y
sudo apt-get install grass-dev -y
At this point grass 6.4.x should be installed with all required headers
svn checkout https://svn.osgeo.org/grass/grass/trunk grass7_trunk
cd into grass7_trunk
Get your config options right, download your required dependencies
(like libcairo-dev for wxgui, etc)
make (The first time it will take loong !)
sudo make install
Due to low RAM, avoid running other software when using the wxgui,
especially when launching it.
The new version of the RaspberryPI is coming with 512Mb RAM... Hint !
Yann Chemin
Researcher@IWMI
Skype/FB: yann.chemin
2013/4/3 Yann Chemin <yann.chemin@gmail.com>:
RAM version)
Screenshot:
How-to:
better place for how-tos is the wiki. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
