I am working on beautifying the output of i.theilsen, a new addon.
For some reason, I cannot apply a grayscale palette.
Yann Chemin wrote:
Rast_init_colors(&colors);
DCELL val1 = ts_min;
DCELL val2 = ceil(ts_max);
Rast_add_d_color_rule(&val1, 0, 0, 0, &val2, 255, 255, 255, &colors);
---------------ts_min, ts_max are known from the data processed,
val1 and val2 are declared as DCELL instead of const DCELL as required,
but if I declare const DCELL val1, then I cannot write stats to it for
palette definition...What I am doing wrong?
If you declare const DCELL val1, you can not pass a pointer to val1 to
another function, because this other function could then easily modify
to contents of that pointer. Rast_add_d_color_rule() requires const
DCELL *, not const DCELL.
Markus M
On Sat, Dec 6, 2014 at 3:59 PM, Markus Metz <markus.metz.giswork@gmail.com>
wrote:
Yann Chemin wrote:
> Hi,
> What I am doing wrong?If you declare const DCELL val1, you can not pass a pointer to val1 to
This is of course true.
Strange, (generated) documentation says const DCELL * [1] which fits with
the source code [2, 3].
I haven't tried compile anything now but isn't `const DCELL` constant
(value) and `const DCELL *` pointer to constant value. While `const DCELL *
const` would be constant pointer to constant value.
Also
const DCELL val;
const DCELL * pval = &val;
should work and carry on the constness which is exactly what should be
happening when calling the Rast_add_d_color_rule() function.
So, I don't understand.
Vaclav
[1]
http://grass.osgeo.org/programming7/color__rule_8c.html#a160535a46694589674f68c60eac23a05
[2] lib/raster/color_rule.c:35:void Rast_add_d_color_rule(const DCELL *
val1, int r1, int g1, int b1, ...
[3] include/defs/raster.h:198:void Rast_add_d_color_rule(const DCELL *,
int, int, int, ...
Markus M
grass-dev mailing list
grass-dev@lists.osgeo.org
Will try again today.
On Sat, Dec 6, 2014 at 3:59 PM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
Yann Chemin wrote:
Rast_add_d_color_rule(&val1, 0, 0, 0, &val2, 255, 255, 255, &colors);ts_min, ts_max are known from the data processed,
palette definition…What I am doing wrong?
Strange, (generated) documentation says const DCELL * [1] which fits with the source code [2, 3].
I haven’t tried compile anything now but isn’t const DCELL
constant (value) and const DCELL *
pointer to constant value. While const DCELL * const
Also
const DCELL val;
should work and carry on the constness which is exactly what should be happening when calling the Rast_add_d_color_rule() function.
So, I don’t understand.
Vaclav
[1] http://grass.osgeo.org/programming7/color__rule_8c.html#a160535a46694589674f68c60eac23a05
[2] lib/raster/color_rule.c:35:void Rast_add_d_color_rule(const DCELL * val1, int r1, int g1, int b1, …
[3] include/defs/raster.h:198:void Rast_add_d_color_rule(const DCELL *, int, int, int, …
Markus M
OK, I found why I got lost in all that…
there is no file appearing in colr/ with the rules made in the code.
On 7 December 2014 at 06:51, Yann Chemin <ychemin@gmail.com> wrote:
Will try again today.On Dec 7, 2014 3:36 AM, “Vaclav Petras” <wenzeslaus@gmail.com> wrote:
Yann Chemin wrote:
Also
const DCELL val;
Vaclav
Markus M
Yann Chemin wrote:
OK, I found why I got lost in all that...
Are you calling Rast_write_colors()?
Also, if the map isn't in the current mapset, the file will go into
<current mapset>/colr2/<mapset>/<map> rather than the mapset
containing the map.
Yes Glynns, that was my missing part, writing the file. … and sleep too.
On 8 December 2014 at 10:37, Glynn Clements <glynn@gclements.plus.com> wrote:
there is no file appearing in colr/ with the rules made in the code.Are you calling Rast_write_colors()?
Also, if the map isn’t in the current mapset, the file will go into
/colr2// rather than the mapset
containing the map.–
