r42876 implements a fairly invasive change to the raster window
handling in 7.0. Specifically:
1. Modules which read and write maps at different resolutions now make
use of the ability to set separate input and output windows
(Rast_set_input_window() and Rast_set_output_window()).
2. Changing the input/output window while maps are open for read/write
(respectively) now generates a fatal error. There should be no need to
do so, and I want to get bug reports for any cases I've overlooked.
Rast_set_window() changes both the input and output windows.
I would appreciate it if people can test any affected modules.
Specifically, the following are the modules and libraries which called
Rast_set_window:
display/d.rast.arrow
display/d.rast.num
general/g.region
imagery/i.atcorr
imagery/i.ifft
imagery/i.rectify
lib/display
lib/gpde
lib/lidar
lib/rst/interp_float
ps/ps.map
raster/r.basins.fill
raster/r.category
raster/r.coin
raster/r.compress
raster/r.describe
raster/r.external
raster/r.flow
raster/r.horizon
raster/r.in.arc
raster/r.in.ascii
raster/r.in.bin
raster/r.in.gdal
raster/r.in.gridatb
raster/r.in.mat
raster/r.in.png
raster/r.in.poly
raster/r.neighbors
raster/r.null
raster/r.proj
raster/r.recode
raster/r.resamp.bspline
raster/r.resamp.filter
raster/r.resamp.interp
raster/r.resamp.rst
raster/r.resamp.stats
raster/r.rescale
raster/r.slope.aspect
raster/r.sun
raster/r.support.stats
raster/r.support
raster/r.surf.idw2
raster/r.to.rast3
raster/r.to.rast3elev
raster/simwe/simlib
raster3d/r3.cross.rast
raster3d/r3.out.vtk
raster3d/r3.to.rast
In particular, anything using the gpde, lidar or rst libraries should
be a priority.
FWIW, the rationale behind the "split window" functionality is to
avoid having r.resamp.* continually changing the window between the
input and output resolutions, as this causes the column mapping to be
regenerated for the input map each time.
