[GRASS-dev] Rast3d_location2coord inconsistent behavior
I have a question about Rast3d_location2coord [1]. It is casting the col, row, depth values to integer like this:
(int) col
instead of using
(int)floor(col)
as a result, col = 0.1 => col = 0 and col = -0.1 => col = 0, which doesn’t seem correct to me. Any opinions?
Thanks, Anna
BTW, similar function Rast_northing_to_row from raster library returns double.
[1] http://grass.osgeo.org/programming7/region_8c_source.html#l00291
Hi Anna,
2014-07-19 19:04 GMT+02:00 Anna Petrášová <kratochanna@gmail.com>:
(int) col
instead of using
(int)floor(col)
as a result, col = 0.1 => col = 0 and col = -0.1 => col = 0, which doesn't
I totally agree that there should be a function that returns the row,
col and depth as double values, so the developer can decide how to
handle these values. Otherwise there would be no convenient way to
determine where coordinates are located in the voxel.
But i am not sure if the integer casting is a bug, since the
Rast_easting_to_col() /Rast_northing_to_row() docs suggest integer
casting as conversion method. There are algorithms in GRASS that use
only integer casting and algorithms that make use of rounding with
floor() before casting to integer.
The problem arise in case of negative column,row or depth values when
casting to integer without rounding to an integer smaller than the
double number. So the question is are there any chances to receive
negative cols,rows and depths?
It does not seems do to me for col and row, since in case of negative
coordinates will west and south always be smaller than east and north,
resulting in always positive cols and rows. And the same should be
true for depths, unless the top is smaller than bottom.
Best regards
Soeren
Thanks, Anna
double.
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Anna,
i have added the function Rast3d_location2coord_double() to the
raster3d library (r61282) that expects x, y and z as double values.
While doing this i discovered a really horrible bug in the coordinate
transformation for rows. The reason for this bug were wrong coordinate
tests in the raster3d library tests. Wrong indexing leaded me to wrong
northern coordinate to row conversion. This bug appeared in case that
coordinates are located exactly at the north/south border between two
voxels.
This is hopefully fixed now. It should be backported to grass7.0 as
well, after heavy testing.
Best regards
Soeren
(int) col
instead of using
(int)floor(col)
Thanks, Anna
double.
On Sat, Jul 19, 2014 at 6:30 PM, Sören Gebbert <soerengebbert@googlemail.com
wrote:
Hi Anna,
> Hi,
> (int) col
> instead of using
> (int)floor(col)
doesn't
Yes, but you still can get negative col, for example when looking for the
neighboring voxels of a voxel on the edge of the 3D raster. Then, the
inconsistency causes problem.
Thanks a lot for implementing Rast3d_location2coord_double.
Anna
Best regards
Soeren
> Thanks, Anna
> double.
2014-07-20 6:10 GMT+02:00 Anna Petrášová <kratochanna@gmail.com>:
<soerengebbert@googlemail.com> wrote:
Hi Anna,
> Hi,
> col,
> (int) col
> instead of using
> (int)floor(col)
> doesn't
Good point, i have updated the Rast3d_location2coord() function to use floor.
Best regards
Soeren
Anna
Best regards
Soeren
> Thanks, Anna
> double.
On Sun, Jul 20, 2014 at 12:04 PM, Sören Gebbert <
>> Hi Anna,
>> > Hi,
>> > col,
>> > (int) col
>> > instead of using
>> > (int)floor(col)
>> > doesn't
floor.
Thanks, I hope it won't be too much overhead comparing to int.
Anna
Best regards
Soeren
> Anna
>> Best regards
>> Soeren
>> > Thanks, Anna
>> > double.
>> > _______________________________________________
