[GRASS-dev] Raster data compression confusion: identical CELL file size
since my local drive was filled up again :slight_smile: I checked raster how data are currently compressed in GRASS GIS 7.2.svn.
According to
https://grass.osgeo.org/grass72/manuals/r.compress.html#used-compression-algorithms
all maps are DEFLATE compressed by default:
"Raster maps are by default ZLIB compressed.
Floating point (FCELL, DCELL) raster maps never use RLE compression; they are either compressed with ZLIB, LZ4, BZIP2 or are uncompressed.
Ehm, now how are FCELL, DCELL compressed by default? Not quite clear to me! This document needs improvements.
Reality check with Sentinel-2 data (3 different bands, same regional extent):
GRASS 7.2.svn (utm37n):~ > r.info -r s2_20151225_B02_10m
min=0
max=22937
GRASS 7.2.svn (utm37n):~ > r.info -r s2_20151225_B04_10m
min=0
max=18849
GRASS 7.2.svn (utm37n):~ > r.info -r s2_20151225_B8A_20m
min=0
max=17210
GRASS 7.2.svn (utm37n):~ >:~ > r.compress s2_20151225_B02_10m -p
<s2_20151225_B02_10m> is compressed (method 2: ZLIB). Data type:
CELL
GRASS 7.2.svn (utm37n):~ >:~ > r.compress s2_20151225_B04_10m -p
<s2_20151225_B04_10m> is compressed (method 2: ZLIB). Data type:
CELL
GRASS 7.2.svn (utm37n):~ >:~ > r.compress s2_20151225_B8A_20m -p
<s2_20151225_B8A_20m> is compressed (method 2: ZLIB). Data type:
CELL
So far so nice. Now the suprising part, while the channels are not identical (obviously, since covering different spectral parts), the map sizes are identical!
GRASS 7.2.svn (utm37n):~ > ls -la
-rw-r–r-- 1 neteler neteler 2539235691 Jun 14 17:14 s2_20151225_B02_10m
-rw-r–r-- 1 neteler neteler 2539235691 Jun 14 17:19 s2_20151225_B03_10m
-rw-r–r-- 1 neteler neteler 2539235691 Jun 14 17:25 s2_20151225_B04_10m
-rw-r–r-- 1 neteler neteler 634878630 Jun 14 20:36 s2_20151225_B05_20m
-rw-r–r-- 1 neteler neteler 634878630 Jun 14 20:37 s2_20151225_B06_20m
-rw-r–r-- 1 neteler neteler 634878630 Jun 14 20:39 s2_20151225_B07_20m
-rw-r–r-- 1 neteler neteler 634878630 Jun 14 20:40 s2_20151225_B11_20m
-rw-r–r-- 1 neteler neteler 634878630 Jun 14 20:42 s2_20151225_B12_20m
-rw-r–r-- 1 neteler neteler 634878630 Jun 14 20:43 s2_20151225_B8A_20m
I would expect different sizes, compression can hardly lead to identical file sizes.
Next test: gzip the file
GRASS 7.2.svn (utm37n):~/grassdata/utm37n/PERMANENT/cell > ls -la s2_20151225_B03_10m
-rw-r–r-- 1 mneteler mneteler 2539235691 Jun 14 17:19 s2_20151225_B03_10m
GRASS 7.2.svn (utm37n):~/grassdata/utm37n/PERMANENT/cell > gzip s2_20151225_B03_10m
GRASS 7.2.svn (utm37n):~/grassdata/utm37n/PERMANENT/cell > ls -la s2_20151225_B03_10m.gz
-rw-r–r-- 1 mneteler mneteler 1456248453 Jun 14 17:19 s2_20151225_B03_10m.gz
R
1456248453/2539235691
[1] 0.5734987
Quite smaller! So I am not at all convinced that these CELL files are currently ZLIB compressed.
From this ticket I would expect something else:
https://trac.osgeo.org/grass/ticket/2349
Ah, and no specific environment variables are set:
GRASS 7.2.svn (utm37n):~ > echo $GRASS_
$GRASS_ADDON_BASE $GRASS_GNUPLOT $GRASS_HTML_BROWSER $GRASS_PAGER
$GRASS_PROJSHARE $GRASS_PYTHON $GRASS_VERSION
A bug?
lower level inconsistency is a no-go.
This should be fixed soonest on all 7.x versions IMHO.
Besides, reading the ticket 2349 mentioned, it is remarkable that NULL map are never compressed by default.
yann
On 6 September 2016 at 13:44, Markus Neteler <neteler@osgeo.org> wrote:
According to
min=0
max=22937
min=0
max=18849
min=0
max=17210
CELL
CELL
CELL
R
[1] 0.5734987
A bug?
grass-dev mailing list
grass-dev@lists.osgeo.org
Yann Chemin
Skype/FB: yann.chemin
On Tue, Sep 6, 2016 at 1:44 PM, Markus Neteler <neteler@osgeo.org> wrote:
According to
Ehm, now how *are* FCELL, DCELL compressed by default? Not quite clear to
The manual says, as you cited:
"Raster maps are by default ZLIB compressed."
What exactly is unclear about this? Should it say "All raster maps ..." ?
extent):
min=0
max=22937
min=0
max=18849
min=0
max=17210
CELL
CELL
CELL
identical!
-rw-r--r-- 1 neteler neteler 2539235691 Jun 14 17:14 s2_20151225_B02_10m
-rw-r--r-- 1 neteler neteler 2539235691 Jun 14 17:19 s2_20151225_B03_10m
-rw-r--r-- 1 neteler neteler 2539235691 Jun 14 17:25 s2_20151225_B04_10m
-rw-r--r-- 1 neteler neteler 634878630 Jun 14 20:36 s2_20151225_B05_20m
-rw-r--r-- 1 neteler neteler 634878630 Jun 14 20:37 s2_20151225_B06_20m
-rw-r--r-- 1 neteler neteler 634878630 Jun 14 20:39 s2_20151225_B07_20m
-rw-r--r-- 1 neteler neteler 634878630 Jun 14 20:40 s2_20151225_B11_20m
-rw-r--r-- 1 neteler neteler 634878630 Jun 14 20:42 s2_20151225_B12_20m
-rw-r--r-- 1 neteler neteler 634878630 Jun 14 20:43 s2_20151225_B8A_20m
file sizes.
The default ZLIB compression level was invalid, causing ZLIB to not
compress at all. Fixed in r69387,8.
Markus M
s2_20151225_B03_10m
-rw-r--r-- 1 mneteler mneteler 2539235691 Jun 14 17:19 s2_20151225_B03_10m
s2_20151225_B03_10m
-rw-r--r-- 1 mneteler mneteler 1456248453 Jun 14 17:19
R
[1] 0.5734987
Compressing a whole file instead of compressing each row separately
(GRASS reads and writes raster data row by row) can lead to higher
compression ratios.
GRASS 7.2.svn (utm37n):~ > echo $GRASS_<tab>
A bug?
On 6 September 2016 at 15:23, Markus Metz <markus.metz.giswork@gmail.com>
> Hi,
> According to
> extent):
> min=0
> max=22937
> min=0
> max=18849
> min=0
> max=17210
> CELL
> CELL
> CELL
identical
> identical!
> file sizes.
Markus M
> s2_20151225_B03_10m
s2_20151225_B03_10m
> s2_20151225_B03_10m
> R
> [1] 0.5734987
compression ratios.
This brings to a long time amount of discussions about parallelization
speed-ups of raster functions being limited by the row-based I/O of GRASS.
Maybe we should look into this for GRASS8...
> A bug?
> Markus
Yann Chemin
    compression ratios.
GRASS. Maybe we should look into this for GRASS8...
https://trac.osgeo.org/grass/wiki/Grass8Planning:
Raster library: Storage in tiles instead of by row
:slight_smile:
Moritz
On Tue, Sep 6, 2016 at 3:23 PM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
According to
“Raster maps are by default ZLIB compressed.”
What exactly is unclear about this? Should it say “All raster maps …” ?
Well, it is perhaps ok but the software appeared to behave differently.
Ah! So, that changes it dramatically :slight_smile: Thanks for the quick fix:
-rw-r–r-- 1 mneteler mneteler 2539235691 Jun 14 17:19 s2_20151225_B03_10m <<-- before
-rw-r–r-- 1 mneteler mneteler 1463080868 Sep 6 16:46 s2_20151225_B03_10m_NEWCOPY <<-- now, generated with r.mapcalc = operator
Great.
And comparing to the previously full file-based gzip test:
1463080868 / 1456248453
[1] 1.004692
… which is now almost the same compression rate.
Some more values:
  • before today’s bugfix:
    du -hs PERMANENT/
    30G PERMANENT/
  • after the bugfix (copies created with r.mapcalc, original raster maps removed):
    du -hs PERMANENT/
    25G PERMANENT/
  • using export GRASS_COMPRESS_NULLS=1 and running r.null -z on all raster maps
    which generates cell_misc/nullcmpr and removes the old uncompressed cell_misc/null:
    du -hs PERMANENT/
    21G PERMANENT/
Now a notable amount of (SSD) disk space is saved - 21GB usage instead of 30GB!
Goal of trac #2349 achieved.
Thanks again,
markusN
PS: it would be great to know through a user message is r.null -z is actually compressing or uncompressing…
Markus Neteler
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
