[GRASS-dev] raster digitizer
When editing a raster using the raster digitizer, the resolution is changes (lower resolution) after saving the edits. Is this the intended behaviour, and if so, what is determining the resolution?
My prefered behaviour would be that the resolution used follows that of the region settings.
On Wed, Mar 4, 2015 at 12:49 PM, Paulo van Breugel <p.vanbreugel@gmail.com>
Hm, that's how it should behave. Are you sure it's not doing that? I don't
change region anywhere in the code so it must use the computational region.
Anna
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Anna,
OK, I did some further testing in another mapset, and it seems it was a problem with the region settings. After setting the region using ‘set computational region from selected map(s)’ the region wasn’t set correctly. It seems to work fine now though. Sorry for the buzz.
On Wed, Mar 4, 2015 at 7:36 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
On Wed, Mar 4, 2015 at 12:49 PM, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Hm, that’s how it should behave. Are you sure it’s not doing that? I don’t change region anywhere in the code so it must use the computational region.
Anna
On Wed, Mar 4, 2015 at 2:07 PM, Paulo van Breugel <p.vanbreugel@gmail.com>
wrote:
Hi Anna,
problem with the region settings. After setting the region using 'set
computational region from selected map(s)' the region wasn't set correctly.
no problem
Anna
don't change region anywhere in the code so it must use the computational
region.
Anna
