hi,
I have a self compiled:
System Info
GRASS Version: 7.1.svn
GRASS SVN revision: 68037
Build date: 2016-03-11
Build platform: x86_64-pc-linux-gnu
GDAL: 2.0.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.8.7.1
Python: 2.7.9
wxPython: 3.0.1.1
Platform: Linux-3.16.0-4-amd64-x86_64-with-debian-8.3
raster is linked:
r.info map=EUD_CP_DEMS_3500025000_AA@demdata
| Map: EUD_CP_DEMS_3500025000_AA@dem Date: Sun Mar 13 01:10:35 2016
| Mapset: demdata Login of Creator: bugs
| DataBase: /home/bugs/grassdata
| Title: ( EUD_CP_DEMS_3500025000_AA )
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: FCELL
| Rows: 40000
| Columns: 40000
| Total Cells: 1600000000
| Projection: Lambert Azimuthal Equal Area
| N: 3000000 S: 2000000 Res: 25
| E: 4000000 W: 3000000 Res: 25
| Range of data: min = -33.27055 max = 3385.91
| Data Description:
| generated by r.external
| Comments:
| r.external input="/home/bugs/gisdata/eudem/EUD_CP-DEMS_3500025000-AA\
| /EUD_CP-DEMS_3500025000-AA.tif" output="EUD_CP_DEMS_3500025000_AA"
when I do a raster query in the map display, I get:
File "/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-
linux-gnu/gui/wxpython/mapwin/buffered.py", line 1236, in
MouseActions
self.OnLeftUp(event)
linux-gnu/gui/wxpython/mapwin/buffered.py", line 1413, in
OnLeftUp
self.mapQueried.emit(x=self.mouse['end'][0],
y=self.mouse['end'][1])
linux-gnu/etc/python/grass/pydispatch/signal.py", line 229,
in emit
dispatcher.send(signal=self, *args, **kwargs)
linux-gnu/etc/python/grass/pydispatch/dispatcher.py", line
349, in send
**named
linux-gnu/etc/python/grass/pydispatch/robustapply.py", line
60, in robustApply
return receiver(*arguments, **named)
linux-gnu/gui/wxpython/mapdisp/frame.py", line 870, in Query
self.QueryMap(east, north, qdist, rast, vect)
linux-gnu/gui/wxpython/mapdisp/frame.py", line 907, in
QueryMap
localized=True)
linux-gnu/etc/python/grass/script/raster.py", line 186, in
raster_what
env=env)
linux-gnu/etc/python/grass/script/core.py", line 461, in
read_command
return handle_errors(returncode, stdout, args, kwargs)
linux-gnu/etc/python/grass/script/core.py", line 329, in
handle_errors
returncode=returncode)
grass.exceptions
CalledModuleError
Module run None ['r.what', '--q', '-rf',
'map=EUD_CP_DEMS_3500025000_AA@demdata', 'null=No data',
'coordinates=3532112.092810,2247474.190841'] ended with
error
Process ended with non-zero return code -11. See errors in
the (error) output.
then I try
r.what map=EUD_CP_DEMS_3500025000_AA@demdata
(Mon Mar 14 20:48:50 2016) Befehl ausgeführt (0 Sek)
DEBUG=3 on
D1/3: G_set_program_name(): r.what
D2/3: G_file_name(): path =
/home/bugs/grassdata/eudem_epsg3035/demdata
D3/3: G_option_to_separator(): key = separator -> sep = '|'
/home/bugs/grassdata/eudem_epsg3035/demdata/WIND
D2/3: file open: read (mode = r)
D2/3: G__read_Cell_head
D2/3: G__read_Cell_head_array
D3/3: region item: proj: 99
D3/3: region item: zone: 0
D3/3: region item: north: 3000000
D3/3: region item: south: 2000000
D3/3: region item: east: 4000000
D3/3: region item: west: 3000000
D3/3: region item: cols: 40000
D3/3: region item: rows: 40000
D3/3: region item: e-w resol: 25
D3/3: region item: n-s resol: 25
D3/3: region item: top: 1.000000000000000
D3/3: region item: bottom: 0.000000000000000
D3/3: region item: cols3: 40000
D3/3: region item: rows3: 40000
D3/3: region item: depths: 1
D3/3: region item: e-w resol3: 25
D3/3: region item: n-s resol3: 25
D3/3: region item: t-b resol: 1
D1/3: G_find_raster2(): name=EUD_CP_DEMS_3500025000_AA
mapset=demdata
D2/3: G_file_name(): path = /home/bugs/grassdata/eudem_epsg3
035/demdata/cell/EUD_CP_DEMS_3500025000_AA
035/demdata/cellhd/EUD_CP_DEMS_3500025000_AA
D3/3: region item: format: -1
D3/3: region item: compressed: 0
mapset=demdata
035/demdata/fcell/EUD_CP_DEMS_3500025000_AA
mapset=demdata
035/demdata/cell_misc/EUD_CP_DEMS_3500025000_AA/f_format
mapset=demdata
mapset=demdata
mapset=demdata
035/demdata/cell_misc/EUD_CP_DEMS_3500025000_AA/gdal
D3/3: found libgdal.so.20
when I query/r.what a GRASS raster:
r.what map=testrmapcalc@demdata coordinates=3566115.70248,2801652.89256
3566115.70248|2801652.89256||1
every works fine
any idea?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/raster-query-r-what-error-with-a-r-external-linked-raster-tp5256308.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
