I have made some necessary updates in
grass70/swig/python/examples/rasteraccess.py
but seem to have missed one:
GRASS 7.0.svn (spearfish60):~ > python
Raster Map Name? elevation.10m
0
File "grass70/swig/python/examples/rasteraccess.py", line 47, in <module>
print rown, myrow[0:10]
TypeError: 'int' object is unsubscriptable
Rast_get_row() returns an integer; if you want to print the first 10
values, use inrast[0:10].
A much older version of the SWIG interface assumed that a non-const
int/float/double pointer argument referred to a row buffer which was
filled in by the function, and would automatically allocate the buffer
and return it as the result. This failed for other cases, so the
feature was removed.
0
right, anyway 'inrast' as a PySwigObject, not a list.
File "rasteraccess.py", line 47, in <module>
print rown, inrast[0:10]
TypeError: 'PySwigObject' object is unsubscriptable
Probably Rast_get_row could return list of values (or empty list on
error) in Python Swig interface...
>> 0
This is a good example of one of SWIG's main limitations. The only
thing it knows about Rast_allocate_buf() is that it returns a void*;
there's no way that it can generate a usable Python object from that
(it doesn't know the actual element type or the number of elements).
In general, it's easier to create objects in Python and pass them to C
than the other way around.
The only real solution is to code wrappers by hand; a C prototype
simply doesn't contain enough information to create a wrapper in
anything beyond the simplest cases.
