[GRASS-dev] Re: #224: cache bug in DGLib
fyi, if we change dglib to use the G_* versions of malloc etc, then it
can't be used as a stand alone library anymore, as it is advertised to be.
http://grass.osgeo.org/dglib/
I'd note the the source code snapshot linked from that page hasn't been
updated since we made the switch from CVS.
Hamish
Right.
I have removed the external, outdated dglib from the server.
Problem solved...
