Hello Markus!
I contend that most of those recent introductions of snprintf() probably don't need it. E.g. the first one (raster3d/r3.in.acii/main.c) can calculate the length of the string to be malloc'ed using strlen() so can guarantee to leave enough space. The second one (db/drivers/dbf/dbfexe.c) can use a fixed field width specifier for the %d format string to fix the length also - again predictable.
So I will work through those and see if I can change them not to use snprintf(). Started it now. I feel if there's something where the length of the resulting string really cannot be predicted, then we should use G_asprintf() because it's there. It does seem to be a matter of personal preference and philosophy though! But I think as Glynn has said before, most of the places snprintf() is used the return value is not checked. So if an overflow was prevented, and the string was not the expected value, the program would just ignore it!
So to summarise - G_snprintf() would be useful to have to easily fix the places that snprintf() was erroneously introduced - so you could put it in, but I think we should discourage its use in favour of calculating how long the string will be and allocating enough memory.
Paul
On Tue, 4 Jul 2006, Markus Neteler via RT wrote:
the snprintf() is used as of today in:
./raster3d/r3.in.ascii/main.c
./db/drivers/dbf/dbfexe.c
./raster/r.support/front/front.c
./raster/r.support/front/check.c
./raster/r.support/front/run.c
./raster/r.support/modhead/check_un.c
./raster/r.support/modhead/modhead.c
./raster/r.support/modhead/ask_format.c
./lib/init/clean_temp.c
./lib/db/dbmi_client/select.c
./lib/gis/user_config.c
./lib/vector/dglib/examples/components.c
I suggest to implement G_snprintf() and use that
function everywhere. Then we can fix in a single place
if needed.
