Maciej Sieczka wrote:
I have tried your recent patch you sent.
It improves things a bit, but doesn't solve the bug yet. See the
attached screndumps. These are xcf files, so you extract the v.buffer
syntax used from them.
As you can see the 4m (buf4.xcf) buffer of my ditches looks kindoff
better - there is no single bulge now, but a buffered ditch. The
problems are that the buffer width is not 4m as declared, but circa 1m
and there is a half-bulge on the left side and some artifact at the
top-left.
In case of the 1m buffer (buf1.xcf) there is no change at all when
compared to the previous result.
If you still have the sample Grass location (vbuffer_bugs) I sent you
please try reproducing these.
patch applied to 6.3-cvs and 6.2 branch.
square_rot_buf30 is fixed.
ditch_1188 is fixed.
1 and 4m buffer around ditches seem to work fine for me, but they did
before the patch. (?) (command taken from "v.info -h ditches_buf1")
I still see the "holes get filled" bug in my own data though,
(v.buffer in=roads bufcol="LANE_COUNT")
so that one's still open.
I seem to remeber Radim commenting on this a long time ago, here we go,
complete with screenshots:
http://grass.itc.it/pipermail/grass-dev/2005-November/020133.html
http://grass.itc.it/pipermail/grass-dev/2005-November/020136.html
http://thread.gmane.org/gmane.comp.gis.grass.devel/9506
This is probably the same bug in v.buffer as you see and nothing to do
with buffcol= (??).
Ahh, I've got you now Obi Wan, the interior-fill bug happens when there
is an interior dangle in my road network ... and I've isolated it to a
vector made up of 10 polylines.
can you try buffering your ditches after
v.clean tool=rmdangle thresh=[big]
I don't understand why you consistently get the error, and I
don't, using the same* dataset. [*] are we really using the same data?
md5sum vbuffer_bugs.tar.bz2
d229fb3e5724acb7bf6314d940fc4def vbuffer_bugs.tar.bz2
Hamish
