Hardeep Singh Rai wrote:
I was doing watershed analysis for spearfish dataset
(spearfish_grass60data-0.1.tar.gz), and on giving command:r.watershed elevation=elevation.dem threshhold=3 basin=raiBasin
accumulation=raiAccu it starts processing of 5 steps. After about 20
minutes, it completes all and throw message: "cloing maps", but do
nothing; prompt never comes. I used it with option -m and without it.
With both cases, "top" commands show ram or sed running with 99 usage
of CPU. Even I waited for 12 hours, but it fail to finish. I am using
GRASS 6.0.1 on Ubuntu.Please suggest some solution.
Hamish wrote:
It's a known bug (#3112). It gets stuck trying to make a huge set of
colormap rules for the new map. If you cancel (^C) you might find the
map was created anyway (???).
Chuck wrote:
The solution is to include a more realistic threshold size.
Yes.
The attached patch shows the problem quite well. As the treshold gets
smaller, the number of areas (cats) grows exponentially. Not only that,
but as the loop within a loop runs, it takes longer and longer to do the
same thing.
The inner loop gets slower I think due to the increased number of color
rules set with G_set_color() that have to be read each time.
#spearfish
g.region rast=elevation.dem
r.watershed elev=elevation.dem basin=tmp_basin thresh=200
d.rast tmp_basin
thresh=200 # 1488 cats
real 0m38.558s
user 0m37.770s
sys 0m0.110s
thresh=100 # 2858 cats
real 0m41.296s
user 0m41.050s
sys 0m0.120s
thresh=50 # 5482 cats
real 0m57.495s
user 0m55.870s
sys 0m0.180s
thresh=37 # 7258 cats
real 1m20.985s
user 1m20.340s
sys 0m0.200s
thresh=25 # 10648 cats
real 3m5.185s
user 3m4.020s
sys 0m0.280s
there are a lot of loops here, but I think the main problem is with so
many calls to G_{get,set}_color():
raster/r.watershed/ram/close_maps2.c
G_init_colors(&colors);
G_make_random_colors(&colors, 1, max);
G_set_color((CELL)0, 0, 0, 0, &colors);
r = 1;
incr = 0;
while(incr >= 0) {
for (gr=130+incr; gr<=255; gr += 20) {
for (rd=90+incr; rd<=255; rd += 30) {
for (bl=90+incr; bl<=255; bl += 40) {
flag = 1;
while (flag) {
G_get_color(r,&red,&green,&blue, &colors);
if((blue*.11 + red*.30 + green*.59) < 100) {
G_set_color(r, rd, gr, bl, &colors);
flag = 0;
if (++r > max) {
gr = rd = bl = 300;
flag = 0;
incr = -1;
if (incr >= 0) {
incr += 15;
if (incr > 120)
incr = 7;
Hamish
(attachments)
rwaters_loop.diff (610 Bytes)
