[GRASS-dev] Re: [bug #4450] (grass) g.remove vect: empty dirs in the $MAPSET/.tmp/$HOSTNAME left
On Sat, 17 Jun 2006 15:04:52 +0200 (CEST)
Markus Neteler via RT <grass-bugs@intevation.de> wrote:
On Sat, Jun 17, 2006 at 01:32:24PM +0200, Maciek Sieczka via RT wrote:
> I have built current Grass 6.1 CVS on Ubuntu Breezy with
> http://mpa.itc.it/markus/tmp/clean_temp2.c apllied.
> I'd prefer each such empty dir be removed right after 'g.remove
> vect'is done, but maybe this is not so critical.
This is an issue of the program creating the vector map in
question. Which one did you use? A script, r.* or v.*?
It is 'g.remove vect' that leaves empty temp dirs in the .tmp. As my
bug report reads:
For each vector file it removes, g.remove leaves 1 empty, redundant
directory in the $MAPSET/.tmp/$HOSTNAME.
To reproduce:
1. Create a vector file
2. Empty your $MAPSET/.tmp/$HOSTNAME entirely.
3. g.remove that vector.
4. See an orphaned empty dir left over.
Maciek
CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej cenie, zapoznaj si? z nasz? ofert?.
ZAPRASZAMY
www.skarpatravel.pl
In a sense yes: 'g.remove vect' doesn't remove the empty temp dirs
in the LOCATION/MAPSET/.tmp/
But that's not even the idea of g.remove.
As my bug report reads:
To reproduce:
My question was: which command did you use to create a vector file?
That command should not leave files in .tmp/. There we have to
search for the problem IMHO.
No - g.remove removes a vector map and doesn't care for tmp files.
Maciek
On Sat, 17 Jun 2006 19:27:55 +0200
> To reproduce:
And I'm telling you that command that created the temp dir, is 'g.remove
vect'. And that it is 'g.remove vect' that is supposed to remove a
temporary dir, which it created.
Or did I missunderstood?
But it should remove temp dirs which it created. Or not?
Maciek
ZAPRASZAMY
www.skarpatravel.pl
> > To reproduce:
Mhh, I didn't know that g.remove creates temporal directories.
Not sure where that should happen:
grep -i mkdir */*.c
lib/do_copy.c:#define mkdir(name, mode) mkdir(name)
lib/do_copy.c: if(mkdir(dst, mode & 0777))
lib/do_copy.c: if(remove(dst) || mkdir(dst, mode & 0777))
Each command who creates temp files/dirs should remove them.
Now I understand and have the bug reproduced.
In fact g.remove vect=map somewhere creates a
directory in .tmp/ when removing an existing vector map.
It happens in G_find_vector2() which is called in
line 24 of
general/manage/lib/do_remove.c
but I am getting list in the G_find_vector2() and subsequent stuff.
line 24 of
That's incorrect; it happens in Vect_delete() at line 26 of that file.
It appears that it moves the vector directory to the .tmp directory
before trying to delete it, but doesn't delete it correctly. From
Vect_delete(), in vector/Vlib/map.c:
    tmp = G_tempfile();
    G_debug (3, "rename '%s' to '%s'", buf, tmp );
    ret = rename ( buf, tmp );
    if ( ret == -1 ) {
  G_warning ( "Cannot rename directory '%s' to '%s'", buf, tmp );
  return -1;
    G_debug (3, "unlink directory '%s'", tmp );
    ret = unlink ( tmp );
unlink() doesn't work on directories, you have to use rmdir() instead.
Or, better still, remove(), which calls either unlink() or rmdir()
depending upon whether the target is a directory; remove() is ANSI,
whereas unlink() and rmdir() are POSIX.
> line 24 of
    tmp = G_tempfile();
    if ( ret == -1 ) {
  return -1;
Thanks for finding it. I have changed unlink() to remove() which
solves the problem.
Glynn:
remove() is ANSI, whereas unlink() and rmdir() are POSIX.
What's our target anyway - ANSI C or POSIX compliance?
fwiw, the debian help page for remove() says:
#include <stdio.h>
CONFORMING TO
       ANSI C, SVID, AT&T, POSIX, X/OPEN, BSD 4.3
while rmdir():
#include <unistd.h>
CONFORMING TO
       SVr4, SVID, POSIX, BSD 4.3
Hamish
ANSI where possible (and practical), POSIX where necessary.
Note that ANSI C's I/O functionality is inadequate for non-trivial
programs, e.g. it doesn't say anything about directories (a system
doesn't even have to /have/ directories to fully implemement ANSI C).
