[GRASS-dev] Re: [bug #4924] (grass) missing quoted path vars in init.sh
Maybe the list has an idea. Can't be too hard.
http://intevation.de/rt/webrt?serial_num=4924&display=History
On Sun, Jul 30, 2006 at 04:08:08PM -0500, William Kyngesburye wrote:
Would that happen even when no monitors are open? Where is the
monitor lockfile stored? not the application folder, maybe the grass
DB? That wouldn't have an affect on this case, since the DB has no
spaces in its pathname.
d.mon is using the path to something in the GRASS application. Even
before quitting GRASS, I can't do anything with d.mon - 'd.mon -L' as
in the exit code, 'd.mon x0', 'd.mon', all give that error:
sh: line 1: /Users/kyngchaos/Applications/0Untitled: No such file or
directory
Should this bug be expanded/renamed to a more general path var
quoting issue? - search out issues like d.mon in commands, and
include the same problem in gis.m/tcl?
>The problem when closing monitors is related to d.mon.
>Apparently something isn't quoted properly to allow for
>spaces in the lock file name of the monitor (or similar).
