[GRASS-dev] Re: [bug #4924] (grass) missing quoted path vars in init.sh
cc grass-dev
http://intevation.de/rt/webrt?serial_num=4924
On Wed, May 09, 2007 at 01:00:44PM -0500, William Kyngesburye wrote:
One more I found - line 843. I quoted the echoed PROMPT_COMMAND for
the bash shell to get it to work:
    echo "PROMPT_COMMAND='$GISBASE/etc/prompt.sh'" >> "$bashrc"
I had to use single-quotes to get it to work. I tried escaped double-
quotes but I still got path splitting errors. I decided not to
commit this myself, in case the single quotes cause other problems
(that fine detail is beyond my shell knowledge).
Any opinions on this?
Markus Neteler wrote:
cc grass-dev
bash parses $PROMPT_COMMAND, so you need yet another level of quoting.
I suspect that you want:
  echo PROMPT_COMMAND="\''$GISBASE/etc/prompt.sh'\'"
