Hamish wrote:
Michael:
It turns out that while arraystats compiles, d.thematic.area and v.class have stopped compiling in develbranch_6. Here is the successful compile of arraystats and the errors with d.thematic.area and v.class
main.c: In function ‘main’:
main.c:133: error: ‘G_OPT_DB_WHERE’ undeclared (first use in this function)In grass7 svn lib/gis/parser.c changed the default G_OPT_WHERE standard
option definition to be G_OPT_DB_WHERE to match the form of other standard
parser options. This wasn't backported to devbr6, but the modules try to
use it anyway.Solutions:
- change devbr6 versions of v.class and d.thematic.area to use old name
This is actually the case.
Michael, did you use the svn version of the modules, or did you use the tarball on my web site ? The latter is grass7-only. And no longer necessary, since I backported to grass6_devel with G_OPT_WHERE.
Moritz
