about d.thematic.area:
I can't set bwidth to zero. My programming skills are very bad, and I haven't done any C anyway so I wasn't able to find the reason for this.
What are you trying to achieve: no borders ? If that's it, try bcolor=none. bwidth=0 is not different from bwidth=1 in the x-monitors or the PNG monitor, but you can see the difference in the PS monitor.
or the PNG monitor,
well, actually it is slightly. width=0 is a little cleaner.
see previous discussions about default render mode for d.vect.
this reminds me that we still need an answer for that question before
releasing 6.3.0.
releasing 6.3.0.
Realistically, I think that it needs to be "c". "g" doesn't work with
vector-based drivers. The others all risk exceeding the 16-bit range
of XDRIVER, and modifying XDRIVER to perform its own clipping is too
radical a change at this stage.
That still leaves the problem with clipping polylines (segments
introduced by clipping are stroked), which I'll look into.
> releasing 6.3.0.
My mistake. Clipped polylines are broken into individual line
segments. It's culled polylines where the problem arises, but that
isn't really an issue if the default is "c".
