[GRASS-dev] Re: diglib and x86_64 problems
Hi William!
No, I'm not aware of this issue - simply because grass compiled without any
errors in diglib. The vector commands I use right now, mostly v.digit, work
fine.
Henning
William Kyngesburye <woklist@kyngchaos.com> wrote:
I don't know about the missing symbols problem, but are you aware of
the OSX 64bit issue in diglib? There is a bug report (got stuck on
the old gforge tracker, and is misnamed):
Wald: Exiting with error?
func=detail&aid=572&group_id=21&atid=204
When you built it a couple weeks ago, did you see any problems running
vector commands? I built from SVN sources a week ago and still had
the problem.
On Mar 5, 2008, at 8:36 AM, Henning Lorenz wrote:
Hello!
I compiled GRASS 6.3.cvs for the x86_64 architecture about two weeks
ago. After a svn update today (30478) I get the error "ld: symbol(s)
not found for architecture x86_64". Have there been any changes
which could cause this?
Henning
Below the complete output after "make" in the diglib directory:
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
On Mar 5, 2008, at 9:54 AM, Henning Lorenz wrote:
Hi William!
fine.
Henning
The error is a runtime.
On Mar 6, 2008, at 1:45 AM, Henning Lorenz wrote:
2. For the time being I use mostly v.digit, and I did not have any problems with it in my or your build.
Why can it be an OSX-x86_64 problem only and not on other systems with the same architecture?
The one definite example was importing a shapefile, but the place it crashed was in the cleaning. Did you try v.in.ogr? Or maybe a v.clean (break tool)? Do you still have the 64bit build to try that?
My builds are 32bit, because of this problem, so you won't see it then.
IT is indeed a mystery why OSX 64bit has this problem. Though I didn't try it on PPC 64bit (no access PPC Macs with Leopard).
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
