Hi Markus
I realized that I sent this email to the wrong mailing list. Here goes:
I believe it's ok:
projection: 1 (UTM)
zone: -24
datum: wgs84
ellipsoid: wgs84
north: 9305500.00000001
south: 9095770.00000001
west: 444000
east: 689130
nsres: 30
ewres: 30
rows: 6991
cols: 8171
cells: 57123461
And my raster is:
| Type of Map: raster Number of Categories:
3 |
| Data Type:
CELL |
| Rows:
6991 |
| Columns:
8171 |
| Total Cells:
57123461 |
| Projection: UTM (zone
-24) |
| N: 9305500.00000001 S: 9095770.00000001 Res:
30 |
| E: 689130 W: 444000 Res:
30 |
| Range of data: min = 0 max =
3 |
So it matches. What might be causing this error/bug?
Antonio
Markus Neteler wrote:
2010/11/18 António Rocha <antonio.rocha at deimos.com.pt>:
Greetings
I'm running GRASS (in Windows) and, for a specific raster, when I try to run
v.to.rast I get this error:
ERROR: G_realloc: unable to allocate 33760000 bytes at areas.c:6781- Is this expectable?
2- is there any fix for this? If not, does anyone has any suggestion to
avoid this error?Did you check the computation region with
g.region -p
? Just to be sure that extent and resolution are right...Markus
