[GRASS-dev] Re: export 3d vector line map to shp
OK,
this ugly patch enables to export 3d shapefile using v.out.ogr
lco="SHPT=ARCZ" ...
Martin
2007/9/11, Martin Landa <landa.martin@gmail.com>:
I got problem exporting 3d GRASS vector map to Shapefile. I have a
vector map with 3d lines (contours).
$ .out.ascii isolines_reggio format=standard | head -n 20
ORGANIZATION:
DIGIT DATE:
DIGIT NAME: martin
MAP NAME: Output from v.overlay
MAP DATE: Tue Sep 11 00:50:19 2007
MAP SCALE: 1
OTHER INFO:
ZONE: 0
MAP THRESH: 0.000000
VERTI:
L 20 1
618866 949571.5625 100
618824.8125 949549.6875 100
618815.8125 949537.1875 100
618820.8125 949524.6875 100
618810.8125 949486.3125 100
618774.5625 949423.6875 100
618767.0625 949372.8125 100
618746.375 949349.8125 100
618728.8125 949360.3125 100
I tried to export the map using
$ v.out.ogr in=isolines_reggio dsn=./ olay=isolines_reggio
For testing...
$ v.in.ogr dsn=isolines_reggio.shp out=test -z
v.out.ascii test format=standard | head -n 20
ORGANIZATION:
DIGIT DATE:
DIGIT NAME: martin
MAP NAME:
MAP DATE: Tue Sep 11 19:46:07 2007
MAP SCALE: 1
OTHER INFO:
ZONE: 0
VERTI:
L 20 1
618866 949571.5625 0
618824.8125 949549.6875 0
618815.8125 949537.1875 0
618820.8125 949524.6875 0
618810.8125 949486.3125 0
618774.5625 949423.6875 0
618767.0625 949372.8125 0
618746.375 949349.8125 0
618728.8125 949360.3125 0
The Z coordinate is lost...
According
http://gdal.org/ogr/drv_shapefile.html
I tried
v.out.ogr in=isolines_reggio dsn=./ olay=isolines_reggio lco=SHPT=ARCZ
ERROR 6: Unknown SHPT value of `ARCZ=YES' passed to Shapefile layer
creation. Creation aborted.
ERROR: Cannot create layer
Thanks for any tip...
Martin
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
... sorry, forgot to attach the patch...
OK,
lco="SHPT=ARCZ" ...
Martin
> Hi,
> ORGANIZATION:
> DIGIT DATE:
> DIGIT NAME: martin
> MAP SCALE: 1
> OTHER INFO:
> ZONE: 0
> VERTI:
> L 20 1
> For testing...
> ORGANIZATION:
> DIGIT DATE:
> DIGIT NAME: martin
> MAP NAME:
> MAP SCALE: 1
> OTHER INFO:
> ZONE: 0
> VERTI:
> L 20 1
> According
> I tried
> Martin
(attachments)
main.c.diff (1.84 KB)
