[GRASS-dev] Re: FW: [GRASS-user] GRASS for windows script solution
3) install the new binary by EXTRACTING it to the proper (i.e., C:\)
directory rather than by dragging the contents into the directory.
Correct?
Yes. For nviz you actually don't need msys, and I still don't know how
dragging the contents of the zip file can cause a problem, but it's all
correct.
I have had several cases in the past where dragging files from the
directory view of a ZIP file manager resulted in incomplete extraction
of the contents.
This may be due to bugs in the archiver's directory GUI and/or filename
handling (e.g. wrong handling of special characters or "hidden" files).
I can't tell you how many hours I wasted trying to get software to
run or compile that wouldn't because the Windows tool "forgot" to
extract some of the files in the ZIP container.
If you want to be sure, forget about all the fancy GUI tools, get
gzip, use it on the command line and live happily ever after ...
Best,
Benjamin
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
7-zip (http://www.7-zip.org/) is also very good and you can use it by right-clicking on the file.
Moritz
Izarc (http://www.izarc.org/) too…
2007/12/6, Moritz Lennert <mlennert@club.worldonline.be>:
gzip, use it on the command line and live happily ever after …
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
