G_percent() is needed after the loop has finished, otherwise "100%\n" is
never printed, and the GUI progress bar* stalls at almost-complete.
consider the order of what happens here, and when will row==nrows (ie 100%):
for (row = 0; row < nrows; row++) { printf("row=%d\n", row); }
G_percent(row, nrows, 2);
[*] (at least in gis.m, I don't know if that's true for the wxGui, but
probably)
ok, I see what you did now with
G_percent(row+1, nrows, 2);
in the loop. But I think that's wrong. For one thing it incorrectly skips
0% done. (typically harmlessly corrected in rounding, but still
incorrect..)
maybe it's just me, but I prefer the historical way.
incorrect..)
IMHO, we want 0% at the very beginning of the operation, and we need
100% at the end.
Ergo, if there are N iterations, G_percent() needs to be called N+1
times (0 to N inclusive), which means that there must be two calls:
one inside the loop, one outside.
For that, you can either call it with 0 before the loop and row+1 at
the end of each iteration, or with row at the start of each iteration
and rows after the loop. I suggest the latter.
