On Wed, 4 Jul 2007, Michael Barton wrote:
I'm trying to make the location wizard actually create a location and, to my
surprise, it wouldn't parse a PROJ.4 string. There is not example of
inputting a PROJ.4 string in the docs, so I've done some experimentation and
found out why. Here is the PROJ.4 string created out of the values in
projection.table and ellipse.tableGRASS 6.3.cvs (spearfish60_test):~ > g.proj -c location=test1
proj4="+proj=ll +a=6378137.000 +f=1/298.257223563 +no_defs"
ERROR: Can't parse PROJ.4-style parameter stringFor this to be accepted by PROJ.4, 'll' must be rewritten as 'longlat', and
the 'f=' parameter must be rewritten as 'rf='.Did I just happen to find the 2 problematic spots in these files, or could
there be others? Do either of you happen to know where the GRASS format
differs from PROJ.4 in other places?
That's two of the main places - others are datum and ellipsoid names although if you put them in numerical format as above the lib/proj code should do it's best at extracting an alphanumeric ellipsoid name now. But the datum names are still a problem.
In fact yes I've been thinking about this the last few days and realised it would be a problem. Using g.proj in this way is more complicated than it first appeared. It may be simpler to manually create the directories (in Python) and write out the PROJ_INFO and PROJ_UNITS files directly. Skeleton DEFAULT_WIND and WIND files would also have to put in too.
As I said I don't have a lot of time to devote to this but I'm working on a proposal for how I think a location creation wizard should work (what is included on each screen etc.) and when finished I will post it to the list, in the hope that the thinking behind it will prove to be some help. I'm doing it blind, i.e. without looking at what's there already in the new GUI - hopefully we can then share the best ideas from both approaches.
Paul
