OK.
configure:2939: checking for G_asprintf in -lgrass_gis
configure:2969: gcc -o conftest -O2 conftest.c -lgrass_gis -L/usr/local/grass-6.3.cvs/lib -lgrass_I -lgrass_vask -lgrass_gmath -lgrass_gis -lgrass_datetime -lgrass_gproj -lgrass_vect -lgrass_dbmibase -lgrass_dbmiclient -lgrass_dgl -lgrass_dig2 -lgrass_rtree -lgrass_linkm -L/usr/local/lib -lgdal >&5
/usr/local/lib/libgeos_c.so.1: undefined reference to `geos::WKBReader::read(std::basic_istream<char, std::char_traits<char> >&)'
/usr/local/lib/libgeos_c.so.1: undefined reference to `geos::WKBWriter::write(geos::Geometry const&, std::basic_ostream<char, std::char_traits<char> >&)'
/usr/local/lib/libgeos_c.so.1: undefined reference to `geos::Point::getCoordinatesRO() const'
/usr/local/lib/libgeos_c.so.1: undefined reference to `geos::WKBWriter::WKBWriter(int, int)'
collect2: ld returned 1 exit status
What does
ldd /usr/local/grass-6.3.cvs/lib/*6.3.cvs*.so
say?
I assume that geos slips in through libgdal. BTW: Mine points to
libgeos.so.2 => /usr/local/lib/libgeos.so.2 (0x0000002a95c03000)
libgeos_c.so.1 => /usr/local/lib/libgeos_c.so.1 (0x0000002a95e0f000)
Is it possible that your GEOS is a bit old? Or that you have two
GEOS libs in parallel?
Just guessing,
On Wed, Jan 17, 2007 at 04:34:30PM +0100, Maciej Sieczka wrote:
Markus Neteler wrote:
> Can you send the config.log file?
Sure. It's already here:
http://www.nabble.com/attachment/8115821/0/config.log.bz2
Paul already looked into it:
http://www.nabble.com/gdal-grass-plugin-fails-during-.-configure-with-GRASS-6.3-CVS-tf2904798.html#a8115502
Maciek
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
OK.
What does
say?
See the attached ldd_grass.txt.
2.2.3 - the latest stable. Do I have have to use GEOS 3 RC? GDAL 1.4
CVS 2007-01-14 didn't complain. Nothing relevant here:
http://www.gdal.org/NEWS.html.
Or that you have two GEOS libs in parallel?
Nope. Only one. Built myself. Installed into /usr/local.
Just guessing,
Thanks, I hope this can be worked out somehow.
Maciek
(attachments)
ldd_grass.txt (32.9 KB)
But yes I have *two*, damn it! And that was the problem!
I have removed the conflicting, second GEOS instalation and now
gdal-grass configures and builds also with GRASS 6.3 CVS, not only with
6.2.
Sorry to Everyone for the fuss and many thanks for this tip, Markus!
Maciek
