[GRASS-dev] Re: [gdal-dev] Setting NODATA to -nan
Hi devs,
FWD of an issue with r.out.gdal in G7. Any ideas?
---------- Forwarded message ----------
Date: Thu, Jul 16, 2015 at 2:07 AM
Subject: Fwd: Re: [gdal-dev] Setting NODATA to -nan
To: neteler@osgeo.org
Hi Markus,
Below you'll find the original report about what discussed on the way to the
party tonight, and then my analysis. The GDAL ticket with the dataset is
https://trac.osgeo.org/gdal/ticket/6036
I'm not sure there's really an issue in practice on the GDAL side. It is just
that dealing with nan is odd to anybody (and the way Windows and Linux
displays nan as a string is different).
Even
To: gdal-dev <gdal-dev@lists.osgeo.org>
Date: Yesterday 11:21:54
Hello,
I've got the following raster exported from GRASS using `r.out.gdal`:
gdalinfo ppp-2015.tif
Driver: GTiff/GeoTIFF
Files: ppp-2015.tif
        ppp-2015.tif.aux.xml
Size is 432017, 216009
Coordinate System is:
GEOGCS["WGS 84",
     DATUM["WGS_1984",
         SPHEROID["WGS 84",6378137,298.257223563,
             AUTHORITY["EPSG","7030"]],
         AUTHORITY["EPSG","6326"]],
     PRIMEM["Greenwich",0],
     UNIT["degree",0.0174532925199433],
     AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.000833300541414,-0.000833298612558)
Metadata:
   AREA_OR_POINT=Area
Image Structure Metadata:
   COMPRESSION=DEFLATE
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
Lower Left (-180.0000000, -90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"S)
Upper Right ( 180.0000000, 90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
Lower Right ( 180.0000000, -90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"S)
Center ( 0.0000000, 0.0000000) ( 0d 0' 0.01"E, 0d 0' 0.01"N)
Band 1 Block=256x256 Type=Float32, ColorInterp=Gray
   NoData Value=nan
   Metadata:
     COLOR_TABLE_RULES_COUNT=5
     COLOR_TABLE_RULE_RGB_0=0.000000e+00 1.681282e+03 255 255 0 0 255 0
     COLOR_TABLE_RULE_RGB_1=1.681282e+03 3.362563e+03 0 255 0 0 255 255
     COLOR_TABLE_RULE_RGB_2=3.362563e+03 5.043845e+03 0 255 255 0 0 255
     COLOR_TABLE_RULE_RGB_3=5.043845e+03 6.725127e+03 0 0 255 255 0 255
     COLOR_TABLE_RULE_RGB_4=6.725127e+03 8.406408e+03 255 0 255 255 0 0
     Generated_with=GRASS GIS 7.0.0
As you can see the NoData is set to `nan`. However, within the data it is
actually `-nan`:
gdallocationinfo ppp-2015.tif -wgs84 42.0776 30.9305
Report:
   Band 1:
     Value: -nan
I have tried to force the NoData to `-nan` as follows but with no joy:
gdal_translate -a_nodata '-nan' -of VRT ppp-2015.tif ppp-2015.vrt
gdalinfo ppp-2015.vrt
Driver: VRT/Virtual Raster
Files: ppp-2015.vrt
        /data/data/ppp_v2c_2015/ppp-2015.tif
GEOGCS["WGS 84",
     DATUM["WGS_1984",
Metadata:
   AREA_OR_POINT=Area
   INTERLEAVE=BAND
Corner Coordinates:
Band 1 Block=128x128 Type=Float32, ColorInterp=Gray
   NoData Value=nan
   Metadata:
Even editing the VRT to contain `<NoDataValue>-nan</NoDataValue>` yields a
positive nan value in gdalinfo.
This looks like it might be a GDAL bug to me? Is there a way I can specify
`-nan` as the NODATA value for this dataset without regenerating it
(it's quite
large)?
Many thanks,
Homme
---------- Forwarded Message ----------
Subject: Re: [gdal-dev] Setting NODATA to -nan
Date: Wednesday 15 July 2015, 20:02:11
To: Homme Zwaagstra <hrz@geodata.soton.ac.uk>
CC: gdal-dev@lists.osgeo.org
Thanks Even,
I have submitted <https://trac.osgeo.org/gdal/ticket/6036&gt; with an
attached TIFF
infested with `-nan` values.
While researching this I cam across this question
<http://stackoverflow.com/q/3772835&gt; which might contain some information of
interest.
Hum looking more closely at representation of nan values in IEEE754, there is
at least 12 million different ways of representing nan for a 32bit floating
point value. And you can indeed have signed NaN... But I'm not sure it is
really useful to set "-nan" as the declared nodata value (it is stored as a
string in GeoTIFF) since even 2 NaN values that could be printed in text form
as "-nan" could have a different binary representation.
The parts of GDAL that test pixel values against nodata have normally a
special behaviour to test the pixel values against nodata, when the nodata
value is one of the NaN values, so I wouldn't expect this apparent
inconsistency to cause problems
For example when running gdalinfo -stats on your file, I get :
ERROR 1: negative-nan-example.tif, band 1: Failed to compute statistics, no
valid pixels found in sampling.
Which is expected since all pixels are set to nan (-nan yeah...), so
ComputeStatistics() actually managed to match the declared nan with the -nan
as pixel values. (which is quite ironical since a property of nan is that nan
!= nan, but here nan ~= -nan :wink: )
Did you run into particular problems beyond this apparent mismatch ?
Even
Spatialys - Geospatial professional services
http://www.spatialys.com
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
it might be that some communication improvement from GRASS-GDAL could be done?
is there a clear NODATA/NAN definition understood within GDAL that we could use within r.out.gdal as a target NODATA value whenever anything than a number is used (i.e. NaN, nan, -nan, helloworld, mynameisbee, etc.)
typically MODIS users are used to -28768 and similar “standard” NODATA numbers, but that maybe another story.
0.01c
On Thu, Jul 16, 2015 at 6:34 PM Markus Neteler <neteler@osgeo.org> wrote:
Hi devs,
Hi Markus,
Below you’ll find the original report about what discussed on the way to the
I’m not sure there’s really an issue in practice on the GDAL side. It is just
Even
Hello,
I’ve got the following raster exported from GRASS using r.out.gdal:
Files: ppp-2015.tif
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4326”]]
Metadata:
AREA_OR_POINT=Area
COMPRESSION=DEFLATE
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000) (180d 0’ 0.00"W, 90d 0’ 0.00"N)
Lower Left (-180.0000000, -90.0000000) (180d 0’ 0.00"W, 90d 0’ 0.00"S)
Upper Right ( 180.0000000, 90.0000000) (180d 0’ 0.00"E, 90d 0’ 0.00"N)
Lower Right ( 180.0000000, -90.0000000) (180d 0’ 0.00"E, 90d 0’ 0.00"S)
Center ( 0.0000000, 0.0000000) ( 0d 0’ 0.01"E, 0d 0’ 0.01"N)
NoData Value=nan
Metadata:
As you can see the NoData is set to nan. However, within the data it is
actually -nan:
Report:
Band 1:
Value: -nan
I have tried to force the NoData to -nan as follows but with no joy:
gdal_translate -a_nodata ‘-nan’ -of VRT ppp-2015.tif ppp-2015.vrt
Files: ppp-2015.vrt
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=BAND
Corner Coordinates:
NoData Value=nan
Metadata:
Even editing the VRT to contain <NoDataValue>-nan</NoDataValue> yields a
-nan as the NODATA value for this dataset without regenerating it
(it’s quite
large)?
Many thanks,
Homme
Thanks Even,
I have submitted <https://trac.osgeo.org/gdal/ticket/6036> with an
attached TIFF
infested with -nan values.
<http://stackoverflow.com/q/3772835> which might contain some information of
interest.
point value. And you can indeed have signed NaN… But I’m not sure it is
really useful to set “-nan” as the declared nodata value (it is stored as a
as “-nan” could have a different binary representation.
value is one of the NaN values, so I wouldn’t expect this apparent
Which is expected since all pixels are set to nan (-nan yeah…), so
Even
grass-dev mailing list
grass-dev@lists.osgeo.org
done?
typically MODIS users are used to -28768 and similar "standard" NODATA
IMHO, anything using NaN as a no-data value should treat all NaNs
equally. The reason being that the only way to reliably propagate the
representation for a NaN is to memcpy() it. Assignment only preserves
NaN-ness, not necessarily the representation.
Actually, r.external is doing it wrong, as it expects any NaNs
supplied by GDAL to exactly match the representation generated by
Rast_set_d_null_value() (the all-ones bit pattern).
Fixed in r65602.
And if the no-data value isn't NaN, you have the issue of comparing
floating-point values for equality. Well, that will probably work so
long as the chosen no-data value is an integer.
2015-07-18 12:48 GMT+02:00 Glynn Clements <glynn@gclements.plus.com>:
Fixed in r65602.
I took liberty to backport it to relbr70 in r65603. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
