Fixed in the cvs.
Michael
On 2/8/07 9:11 AM, "Moritz Lennert" <mlennert@club.worldonline.be> wrote:
On 08/02/07 17:00, Michael Barton wrote:
Moritz,
I'll try to see what's going on with this. It probably has to do with the
necessary link between a layer tree and a display. A better error message
would likely be "You need to open a display before adding map layers"yes, definitely better.
Thanks !
Moritz
Michael
On 2/8/07 6:11 AM, "Moritz Lennert" <mlennert@club.worldonline.be> wrote:
Michael,
Since you have been busy working on error catching in gis.m: I've always
found that the error that occurs when you try to add a layer even though
there is no open map display quite difficult to understand for newbies:invalid command name ".mainframe.frame.pw1.f0.frame.pgs.fpage_1.sw.tree_1"
while executing
"$tree($mon) selection get"
(procedure "GmTree::add" line 11)
invoked from within
"GmTree::add vector"
("uplevel" body line 1)
invoked from within
"uplevel \#0 $cmd"
(procedure "Button::_release" line 18)
invoked from within
"Button::_release .mainframe.topf.tb0.bbox2.b0"
(command bound to event)Would it be possible to catch this and produce a nicer error message
such as: "You need to open a map display first." ?Moritz
Center for Social Dynamics and Complexity
Arizona State Universityphone: 480-965-6213
fax: 480-965-7671
phone: 480-965-6213
fax: 480-965-7671
