[GRASS-dev] Re: GIS Manager and Map Display 1 faults on Ubuntu 6.06
Hello Stefan,
had the same problem with Ubuntu 6.06. Now that I installed 6.10 this problem
is gone. Haven't figured out what exactly the original problem was, though.
Kind regards,
Andreas
I did not care about the kernel - he is running with a realtime-patch.
Maybe this is causing the failures - but I do not understand how this can
affect grass? Are there known problems when grass (gui-) functions are
heavily interrupted?
I guess I don't know the answer to this. Maybe someone else does.
Sometimes, I run a VMWARE server with both W98 and W2k on this box too. But
they are run pretty smooth; so for me the base system is stable.
Does g.region work OK? If not, it will affect a number of features in the
display controls of the GIS Manager.
Michael
Mit freundlichen Grüßen / With kindest regards
Stefan Paulick
http://www.urbeli.com
mailto://stefan.paulick@urbeli.com
Andreas Gros (PhD-Student)
Fieldstation Fabrikschleichach
University Wuerzburg
Glashuettenstr. 5
96181 Rauhenebrach
Tel.: +49 931 888 3079
Fax.: +49 931 888 3089
had the same problem with Ubuntu 6.06. Now that I installed 6.10 this problem is gone. Haven't figured out what exactly the original problem was, though.
Sorry Andreas, switching to 6.10 is no option, because we want to benefit from "LTS"
I collected the latest CVS code, and now gis.m flashes the initial graphic and is gone.
d.m works fine; distclean didn't change the behaviour.
I get no error message, only the note:
D3/5: region item: n-s resol3: 1
D3/5: region item: t-b resol: 1
D3/5: G_adjust_Cell_head: epsilon_ns: 2.77778e-07, epsilon_ew: 1e-06
GRASS 6.3.cvs (grassuser):/gd >
Looks like not all fatal conditions are caught.
--> Is there a way to monitor the script execution during startup?
Stefan Paulick
