[GRASS-dev] Re: [grass-addons] r659 - trunk/grassaddons/gui/gui_modules
Martin,
Are you thinking that we should change all calls to GRASS commands to use
the new cmd module?
Michael
On 5/16/07 2:09 AM, "landa@grass.itc.it" <landa@grass.itc.it> wrote:
Author: landa
Date: 2007-05-16 11:09:42 +0200 (Wed, 16 May 2007)
New Revision: 659
Modified:
   trunk/grassaddons/gui/gui_modules/mapdisp.py
Log:
fixing 'Zoom to saved region'
Modified: trunk/grassaddons/gui/gui_modules/mapdisp.py
--- trunk/grassaddons/gui/gui_modules/mapdisp.py 2007-05-15 23:55:41 UTC (rev
658)
+++ trunk/grassaddons/gui/gui_modules/mapdisp.py 2007-05-16 09:09:42 UTC (rev
659)
@@ -851,21 +851,21 @@
         zoomreg = {}
         dlg = SavedRegion(self, wx.ID_ANY, "Zoom to saved region extents",
- pos=wx.DefaultPosition, size=wx.DefaultSize,
- style=wx.DEFAULT_DIALOG_STYLE,
- loadsave='load')
+ pos=wx.DefaultPosition, size=wx.DefaultSize,
+ style=wx.DEFAULT_DIALOG_STYLE,
+ loadsave='load')
         if dlg.ShowModal() == wx.ID_CANCEL:
             dlg.Destroy()
             return
         wind = dlg.wind
- cmd = "g.region -ugp region=%s" % wind
+ cmdString = "g.region -ugp region=%s" % wind
- try:
- p = Popen(cmd, shell=True, stdin=PIPE, stdout=PIPE, stderr=PIPE,
close_fds=True)
+ p = cmd.Command (cmdString)
- output = p.stdout.read().split('\n')
+ if p.returncode == 0:
+ output = p.module_stdout.read().split('\n')
             for line in output:
                 line = line.strip()
                 if '=' in line: key,val = line.split('=')
@@ -877,14 +877,6 @@
self.ZoomHistory(self.Map.region['n'],self.Map.region['s'],self.Map.region['e'
],self.Map.region['w'])
             self.UpdateMap()
- if p.stdout < 0:
- print >> sys.stderr, "Child was terminated by signal",
p.stdout
- elif p.stdout > 0:
- #print >> sys.stderr, p.stdout
- pass
- except OSError, e:
- print >> sys.stderr, "Execution failed:", e
         dlg.Destroy()
     def SaveDisplayRegion(self, event):
grass-commit-addons mailing list
grass-commit-addons@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass-commit-addons
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Michael,
2007/5/16, Michael Barton <michael.barton@asu.edu>:
the new cmd module?
yes, I think so.
Martin
Michael
> Author: landa
> New Revision: 659
> Modified:
> Log:
> 658)
> 659)
> zoomreg = {}
> - loadsave='load')
> + loadsave='load')
> dlg.Destroy()
> return
> wind = dlg.wind
> - try:
> close_fds=True)
> for line in output:
> line = line.strip()
> self.UpdateMap()
> - if p.stdout < 0:
> p.stdout
> - pass
> dlg.Destroy()
phone: 480-965-6213
fax: 480-965-7671
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
Seems like a good idea, especially for updating in the future. For all new
commands, I'll follow this syntax. As we all have time, we can go back and
change the existing code. It shouldn't be a huge task.
Michael
On 5/16/07 8:32 AM, "Martin Landa" <landa.martin@gmail.com> wrote:
Michael,
the new cmd module?
yes, I think so.
Martin
Michael
Author: landa
New Revision: 659
Modified:
Log:
(rev
658)
(rev
659)
         zoomreg = {}
- loadsave='load')
+ loadsave='load')
             dlg.Destroy()
             return
         wind = dlg.wind
- try:
stderr=PIPE,
close_fds=True)
             for line in output:
                 line = line.strip()
e'
             self.UpdateMap()
- if p.stdout < 0:
p.stdout
- pass
         dlg.Destroy()
phone: 480-965-6213
fax: 480-965-7671
phone: 480-965-6213
fax: 480-965-7671
the new cmd module?
This interface is broken, and needs to be replaced.
           self.module = subprocess.Popen(self.cmd, shell=True,
Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong.
Just how clearly do I have to say this before it sinks in:
  DO NOT USE THE SHELL
Using the shell means problems with spaces, quotes and other shell
metacharacters. There is no reason to use it. So don't.
Glynn,
2007/5/16, Glynn Clements <glynn@gclements.plus.com>:
> the new cmd module?
OK, then we need to fix Command class... (I will look at it tomorrow)
Martin
grassgui mailing list
grassgui@grass.itc.it
http://grass.itc.it/mailman/listinfo/grassgui
The good thing about using the command class is that if we get it right
THERE, then it will be right throughout the GUI, and we won't have to change
each instance that we call a GRASS command.
This was the gist of my post. Martin is doing the cmd.py module and can fix
it so that it doesn't use SHELL.
Michael
On 5/16/07 10:15 AM, "Martin Landa" <landa.martin@gmail.com> wrote:
Glynn,
the new cmd module?
Martin
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
I am not quite sure if this patch OK...
- self.module = subprocess.Popen(self.cmd, shell=True,
+ cmdList = cmd.split(' ')
+ self.module = subprocess.Popen(args=cmdList, shell=False,
                                           stdin=subprocess.PIPE,
                                           stdout=subprocess.PIPE,
                                           stderr=subprocess.PIPE,
Martin
Michael
> Glynn,
>>> the new cmd module?
> Martin
>> _______________________________________________
phone: 480-965-6213
fax: 480-965-7671
Nope. In fact, it's a good example of why the interface is wrong
(think about how it will behave if you have a space in an argument).
The problem isn't the implementation, it's the interface.
Let me put it another way: which of the following is correct?
1. int main(char *cmd)
2. int main(int argc, char **argv)
The correct answer is #2. A command isn't a string, it's a list of
strings, and that is the interface which you need to provide.
Taking a list of strings, combining them to form a single string, then
splitting the list into multiple strings will introduce errors, i.e.
the list you end up with won't always be the original list.
The existing interface splits them according to the shell's syntax,
which has several problems; not least of which is that /bin/sh and
cmd.exe have radically different syntax, meaning that you would often
need to write separate Unix/Windows versions of any code which calls
cmd.Command().
You're proposed patch is worse, in that it becomes entirely impossible
to pass an argument which contains a space (these are quite common for
filenames on Windows).
The only realistic solution is not to combine them in the first place.
IOW, the cmd parameter should be a list, and Popen should be called
as:
  self.module = subprocess.Popen(args=self.cmd,
You then need to change everything which calls cmd.Command() to pass a
list, not a string.
This is helpful. But I will wait to make any changes until this is worked
out--since it looks like we will also need to redefine the original command
string (i.e., to make it a proper list) prior to calling cmd.Command.
Michael
cmd.Command().
as:
list, not a string.
phone: 480-965-6213
fax: 480-965-7671
I've fixed cmd.Command itself and all of the straightforward uses.
AFAICT, GUI.parseCommand() is probably still broken:
menuform.py:1075: cmdlst = cmd.split(' ')
So we'll need to send it a list consisting of [command+flags, option=val,
option=val,...]. Right?
This actually might be fine. It looks like it is only checking to see if
there is a space in the command string and returning an error message is
there is. It making sure that the only thing being passed on to menuform is
a simple GRASS command without arguments.
Michael
phone: 480-965-6213
fax: 480-965-7671
Example:
        dbDescribe = cmd.Command (cmd = ["db.describe", "-c",
           "table=%s" % self.parent.tablename,
           "driver=%s" % self.parent.driver,
           "database=%s" % self.parent.database])
Ah; okay.
Example:
Thanks. This is a good example.
Michael
Ah; okay.
phone: 480-965-6213
fax: 480-965-7671
Glynn,
sorry I was some days out of the office, anyway thanks for fixing it!
And also thanks for explanation.
Martin
2007/5/18, Michael Barton <michael.barton@asu.edu>:
> Example:
Michael
> Ah; okay.
phone: 480-965-6213
fax: 480-965-7671
