Comment By: Martin Landa (martinl)
Parameter 'layer' is completely ignored during printing. It
means *all* available connections are printed, which I think make
sense. Maybe the module description is not so clear.
Thanks for the information. Yes, module description is not clear.
For GRASS7 maybe it would be good to add parameter
"option=add,delete,print"For 'add' you need map,driver,database,table,key,layer For 'delete'
you need map,layer For 'print' just map
Maciek
