[GRASS-dev] Re: [GRASS-CVS] glynn: grass6/lib/pngdriver Graph_set.c, 1.1, 1.2 Makefile, 1.4, 1.5 pngdriver.h, 1.3, 1.4 write.c, 1.1, 1.2
I am not able to compile pngdriver because of missing read.c, etc.
make: *** No rule to make target `OBJ.i686-pc-linux-gnu/read.o',
needed by `/usr/src/gis/grass6/dist.i686-pc-linux-gnu/lib/libgrass_pngdriver.6.3.cvs.so'.
Stop.
is there anything I have missed? Thanks!
Martin
2006/11/13, grass@intevation.de <grass@intevation.de>:
Author: glynn
Update of /grassrepository/grass6/lib/pngdriver
In directory doto:/tmp/cvs-serv12051/lib/pngdriver
Modified Files:
        Graph_set.c Makefile pngdriver.h write.c
Log Message:
Initialise framebuffer from $GRASS_PNGFILE if $GRASS_PNG_READ = TRUE
Index: Graph_set.c
RCS file: /grassrepository/grass6/lib/pngdriver/Graph_set.c,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- Graph_set.c 1 Jun 2006 17:40:22 -0000 1.1
+++ Graph_set.c 13 Nov 2006 14:29:25 -0000 1.2
@@ -92,6 +92,10 @@
        modified = 1;
+ p = getenv("GRASS_PNG_READ");
+ if (p && strcmp(p, "TRUE") == 0)
+ read_image();
        return 0;
Index: Makefile
RCS file: /grassrepository/grass6/lib/pngdriver/Makefile,v
retrieving revision 1.4
retrieving revision 1.5
diff -u -d -r1.4 -r1.5
--- Makefile 19 Sep 2006 10:18:48 -0000 1.4
+++ Makefile 13 Nov 2006 14:29:25 -0000 1.5
@@ -24,11 +24,13 @@
        Raster_RGB.o \
        Raster_int.o \
        Respond.o \
+ read.o \
+ read_ppm.o \
        write.o \
        write_ppm.o
ifneq ($(USE_PNG),)
- LIB_OBJS += write_png.o
+ LIB_OBJS += read_png.o write_png.o
endif
include $(MODULE_TOPDIR)/include/Make/Lib.make
Index: pngdriver.h
RCS file: /grassrepository/grass6/lib/pngdriver/pngdriver.h,v
retrieving revision 1.3
diff -u -d -r1.3 -r1.4
--- pngdriver.h 19 Sep 2006 10:18:48 -0000 1.3
+++ pngdriver.h 13 Nov 2006 14:29:25 -0000 1.4
@@ -22,10 +22,16 @@
extern int linewidth;
+extern void read_image(void);
+extern void read_ppm(void);
+extern void read_pgm(void);
+extern void read_png(void);
extern void write_image(void);
extern void write_ppm(void);
extern void write_pgm(void);
extern void write_png(void);
extern void init_color_table(void);
extern void PNG_Box_abs(int,int,int,int);
Index: write.c
RCS file: /grassrepository/grass6/lib/pngdriver/write.c,v
--- write.c 1 Jun 2006 17:40:22 -0000 1.1
+++ write.c 13 Nov 2006 14:29:25 -0000 1.2
@@ -25,7 +25,7 @@
                write_png();
#endif
        else
- G_fatal_error("Graph_Close: unknown file type: %s", p);
+ G_fatal_error("write_image: unknown file type: %s", p);
        modified = 0;
grass-commit mailing list
grass-commit@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass-commit
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
Stop.
No, I forgot to "cvs add" the new files. Fixed now.
> needed by
>s.so'. Stop.
aha! that would explain it. Thank Glynn - bob and I were scratching our heads
on that one...
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
