[GRASS-dev] Re: [GRASS-CVS] hamish: grass6/lib/init init.sh, 1.119, 1.120
On Sat, Oct 06, 2007 at 07:05:00AM +0200, grass@intevation.de wrote:
Author: hamish
Update of /grassrepository/grass6/lib/init
In directory doto:/tmp/cvs-serv6411
Modified Files:
        init.sh
Log Message:
add test so don't overwrite VAR file without testing. I just commented the whole
thing out though after fixing it, as the VAR and $MAPSET/dbf/ should be
created on demand. To a raster-only or postgres-only user they are just
file pollution. code bug #502
Index: init.sh
RCS file: /grassrepository/grass6/lib/init/init.sh,v
retrieving revision 1.119
retrieving revision 1.120
diff -u -d -r1.119 -r1.120
--- init.sh 3 Oct 2007 08:30:48 -0000 1.119
+++ init.sh 6 Oct 2007 05:04:58 -0000 1.120
@@ -495,9 +495,10 @@
                        cp "$GISDBASE/$LOCATION_NAME/PERMANENT/WIND" "$LOCATION/WIND"
                        echo "Missing WIND file fixed"
                        # predefine DBF driver
- echo "DB_DRIVER: dbf" > "$LOCATION/VAR"
- echo "DB_DATABASE: \$GISDBASE/\$LOCATION_NAME/\$MAPSET/dbf/" >> "$LOCATION/VAR"
- mkdir "$LOCATION"/dbf
+ # why is this needed ??
+ #echo "DB_DRIVER: dbf" > "$LOCATION/VAR"
+ #echo "DB_DATABASE: \$GISDBASE/\$LOCATION_NAME/\$MAPSET/dbf/" >> "$LOCATION/VAR"
+ #mkdir "$LOCATION"/dbf
This is needed, if you start GRASS from CMD line with
full path to a non-existing mapset (which is then created).
So this should be restored somehow.
Above was there for many months without problems. The recent
problem seems to arise from a different modification.
PS: I find init.sh rather overloaded and hard to understand.
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
Author: hamish
Modified Files:
        init.sh
Log Message:
the whole
Index: init.sh
"$LOCATION/WIND"
Why is the dbf path creation needed ? You might never want to use dbf on
this new mapset...
I guess the automatic dbf path creation should be part of db.connect...
Yes, the revision just before
(http://freegis.org/cgi-bin/viewcvs.cgi/grass6/lib/init/init.sh.diff?r1=1.118&r2=1.119):
RCS file: /home/grass/grassrepository/grass6/lib/init/init.sh,v
retrieving revision 1.118
diff -u -r1.118 -r1.119
--- grass6/lib/init/init.sh 2007/09/20 14:18:01 1.118
+++ grass6/lib/init/init.sh 2007/10/03 08:30:48 1.119
@@ -1,7 +1,7 @@
#!/bin/sh
-# $Id: init.sh,v 1.118 2007/09/20 14:18:01 moritz Exp $
+# $Id: init.sh,v 1.119 2007/10/03 08:30:48 markus Exp $
# MODULE: GRASS Initialization
# AUTHOR(S): Original author unknown - probably CERL
@@ -685,6 +685,11 @@
   echo "Building user fontcap ..."
   g.mkfontcap
fi
+# predefine DBF driver if DB connection not defined
+echo "DB_DRIVER: dbf" > "$LOCATION/VAR"
+echo "DB_DATABASE: \$GISDBASE/\$LOCATION_NAME/\$MAPSET/dbf/" >>
"$LOCATION/VAR"
+mkdir "$LOCATION"/dbf
trap "" 2 3 15
Moritz
Markus:
Moritz:
ie the missing check for the existence of VAR before overwriting the file.
H
____________________________________________________________________________________
Be a better Globetrotter. Get better travel answers from someone who knows. Yahoo! Answers - Check it out.
http://answers.yahoo.com/dir/?link=list&sid=396545469
HamishB wrote:
Markus:
Moritz:
(FreeGIS.org):
Would like to check that but...:
Python Exception Occurred
  File "/home/www/viewcvs/lib/viewcvs.py", line 2630, in run_cgi
    main()
  File "/home/www/viewcvs/lib/viewcvs.py", line 2608, in main
    view_diff(request, full_name[:-5])
  File "/home/www/viewcvs/lib/viewcvs.py", line 2335, in view_diff
    if revcmp(rev1, rev2) > 0:
  File "/home/www/viewcvs/lib/viewcvs.py", line 1098, in revcmp
    rev2 = map(int, string.split(rev2, '.'))
ValueError: invalid literal for int(): 119)
Ouch?
PS: Martin has prepared a CVS backup via rsync and with viewCVS:
http://josef.fsv.cvut.cz/cgi-bin/viewcvs.cgi/grass6/lib/init/init.sh?root=grass&r1=1.118&r2=1.119
So, seems to be my fault (the overwrite, not that the VAR file disappears!)
View this message in context: http://www.nabble.com/Re%3A--GRASS-CVS--hamish%3A-grass6-lib-init-init.sh%2C-1.119%2C-1.120-tf4579018.html#a13078288
Sent from the Grass - Dev mailing list archive at Nabble.com.
> Author: hamish
> Modified Files:
> init.sh
> Log Message:
> commented the whole thing out though after fixing it, as the VAR and
> $MAPSET/dbf/ should be created on demand. To a raster-only or
> postgres-only user they are just file pollution. code bug #502
> Index: init.sh
> "$LOCATION/WIND" echo "Missing WIND file fixed"
Markus:
so
#typo
user:~ $ grass63 grassdata/spearfish60/user11
Is meant to create:
grassdata/spearfish60/user11/VAR
grassdata/spearfish60/user11/WIND
grassdata/spearfish60/user11/dbf/
(current CVS makes the new mapset but not the VAR and dbf/)
I would think we should throw an error if the mapset doesn't exist
(typo), and some '-n' flag is needed to create a new mapset from the
command line.
And don't create the VAR and dbf/ until needed. (why do those need to
exist before any vector maps with tables are created?)
Hamish
> Author: hamish
> Modified Files:
> init.sh
> Log Message:
> Index: init.sh
Markus:
so
#typo
Is meant to create:
Yes, because only then it becomes a valid mapset without subsequent
errors.
command line.
OK, sounds reasonable to me (less surprises in the script behaviour).
Because any db./v. command will fail if those aren't present. DBF is the
default (still). Costs only a very few bytes.
Alternatively, fix all commands to auto-create when VAR and dbf/ are needed
but I suspect that this would be lots of work. Better do it in one place
right
at the beginning (then we can also easily switch to SQLite as default DB
driver
in future.
View this message in context: http://www.nabble.com/Re%3A--GRASS-CVS--hamish%3A-grass6-lib-init-init.sh%2C-1.119%2C-1.120-tf4579018.html#a13103885
