On Jan 1, 2008, at 3:13 AM, grass-dev-request@lists.osgeo.org wrote:
#12: gis.m->Help->About system doesn’t work (launches another gis.m instance)
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.0
Component: default | Version: unspecified
Resolution: | Keywords:
Comment (by cmbarton):
Replying to [ticket:12 neteler]:
Clicking on ‘About System’ within the gis.m Help menu launches a new set
of gis.m windows instead of opening a tcl/tk window with system
parameters. The newly created gis manager toolbar says "Tk System
Information".
PS: moved here from
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=553&group_id=21
Is this function worth the trouble of trying to fix?
This is just a symptom of a larger problem, namely that the Gm::errmsg
procedure is defined in gm.tcl, which cannot be "source"d (because
doing so will “run” gis.m).
Gm::errmsg belongs in a “library”, i.e. a Tcl source file which can be
"source"d from other Tcl source files.
Also: gm.tcl calls Gm::errmsg from top-level code at the beginning of
the file (the code which copies various g.gisenv settings into $env),
although the procedure isn’t actually defined until much later in the
file. If any of those “catch” statements actually catch an error, the
handler will throw an error due to Gm::errmsg being undefined.
Making a library and moving Gm::errmsg to it is pretty easy to fix (just a LOT of find/replace throughout the GUI code). Anything else that you know of should come out of gm.tcl and into such a library?
However, making the ‘get system info’ function work is more trouble. As I said in the rest of the post, it’s very old code. Is it worth bothering with to have the GUI launch a window with a bit of minimal system info?
Michael
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
