On Mar 28, 2008, at 9:00 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Fri, 28 Mar 2008 14:00:24 -0000
Subject: [GRASS-dev] Re: [GRASS GIS] #106: wxgrass: zoom to
computational region does not respect resolution set with g.region
To: undisclosed-recipients:;
Message-ID: <051.53d633c3c615e7b1f2ee8c9f9754e42f@osgeo.org>
Content-Type: text/plain; charset="utf-8"#106: wxgrass: zoom to computational region does not respect resolution set with
g.region
Reporter: mlennert | Owner: martinl
Type: enhancement | Status: assigned
Priority: major | Milestone: 6.4.0
Component: Python | Version: svn-trunk
Resolution: | Keywords: wxgrass resolution zoom
Comment (by mlennert):More info is always better (could be formatted a bit better, with at least
two more commas, but possibly spaces to make coordinates readable), but I
do think a visualisation mode showing the exact computational region would
be far superior. I won't insist though, as I seem to be the only one
asking for this...
I think we agree, but I don't understand what you are asking for. There is a red bounding box that shows the exact computational region in the display, regardless of what you zoom the *displa*y to. Maybe you're not seeing it because it corresponds to the display. Turn it on (pull-down on the right) and zoom out some. You should see a bounding box that matches your computational region. If you zoom in more than the computational region you won't see it though.
Michael
