On Mar 1, 2008, at 1:54 PM, grass-dev-request@lists.osgeo.org wrote:
Date: Sat, 1 Mar 2008 18:59:41 +0100
Subject: [GRASS-dev] winGRASS RC5 Fails on Creating a New Projection
To: "GRASS Developer Mailing List" <grass-dev@lists.osgeo.org>
Message-ID: <005401c87bc6$0618d190$0201a8c0@notebookmarco>
Content-Type: text/plain; charset="us-ascii"
From startpanel, define new location with epsg codes
Used 4326 for WGS84
Returned the following message:
g.proj returned the following informational message: child killed: SIGABRT
Ahha, the SIGABRT problem. I have no idea what it means, but have encountered it before. What that has meant when I've run into it is that something wasn't installed right. If you try to drag-and-drop the contents of the compressed WinGRASS distribution file, sometimes something gets missed. I assume that it's some kind of hidden (to Windows) file, but don't know what it is. The result is kind of random SIGABRT errors. I suspect that it is a problem with some Windows unzip applications but not others, though it may be a function of Windows copy I suppose.
My solution is to EXTRACT the files to C:/ instead of doing a drag-and-drop.
Try it and see if this fixes your problem. It's kind of black magic and I wish I knew exactly what caused it. But the error is inscrutable, at least to me.
Michael
> Used 4326 for WGS84
> SIGABRT
and-drop.
I'm not sure about Windows, but on Unix the most common reason for
SIGABRT is due to assert() (which calls abort(), which raises
SIGABRT).
A failed assert() should print the actual test to stderr, but the GUI
might be discarding that.
As for why drag-and-drop may not work, it's important to extract
archives in binary mode, not text mode or "autodetect" (i.e. don't
perform LF->CRLF conversion).
