On Aug 8, 2008, at 9:00 AM, <grass-dev-request@lists.osgeo.org> wrote:
Date: Fri, 08 Aug 2008 17:53:48 +0200
From: Moritz Lennert <mlennert@club.worldonline.be>
Subject: [GRASS-dev] [Fwd: Re: [GRASS-user] vector layer labelling
doesn't work....]
To: grass-dev <grass-dev@lists.osgeo.org>
Message-ID: <489C6C0C.7070302@club.worldonline.be>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Forwarding to dev-list in case someone wants to react. Summary: in
vector area maps, labels are only displayed when centroids are also
displayed.
Proposal: automatically display centroids, when attribute label option
is activated.
This is ugly for areas. It would be much better to allow labels to be displayed without centroids being displayed.
Michael
doesn't work....]
displayed.
is activated.
Well, currently, if you want to display labels, you have to display the centroids, but you can make them points with size 1, so hardly visible...
Then you would need a new ltype parameter to determine for which types of features you would like to see labels. Otherwise, in a layer (using new proposed terminology) mixing different types of features, GRASS wouldn't know for which type you want labels, since you did not need to activate them with the type parameter...
So, three choices:
1) We automatically activate centroids when the user choses to display lables. Maybe we could allow a point size of 0 to not display the centroid at all.
2) We add an ltype parameter.
3) We don't change anything and educate users
Moritz
doesn't work....]
displayed.
is activated.
Nope, I was wrong, it actually seems possible (and easier than I thought). Try the attached patch which should allow displaying area labels without centroids.
Moritz
(attachments)
d.vect.diff (1.85 KB)
